Question about Brother MFC 420CN All-In-One InkJet Printer
Why wont brother mfc-420cn feed paper to print?
SOURCE:
Mix-it-up
  • 832 Answers
SOURCE: Brother Mfc 420cn says machine error AF
Open the small cover that hides the scanner flat cable. It has to be reconnected to the main pcb.
Posted on Oct 23, 2007
SOURCE: my brother mfc 420cn printer won't print
i reset the printer to the original factory settings, and now it works. thanks for your concern and help, richard
Posted on Feb 22, 2008
Mix-it-up
  • 832 Answers
SOURCE: Double prints or Text shadow printing by MFC 420CN
yes. you have to run the alignment feature. press ink - set - arrow-down til alignment. After alignment test print read the paper and choose the right setting by nr.
Posted on Apr 09, 2008
komguy
  • 2306 Answers
SOURCE: clean brother encoder strip
The encoder strip is barely visible thru the top in front of the printhead, if you can see it without taking all apart, you use a Q-tip just damp with water and wipe each side as far as you can reach.
Posted on Oct 21, 2009
cene765
  • 787 Answers
SOURCE: I have a brother mfc-420cn. I am getting a unable to clean messa
Do you mean "unable to clean"?If it this follow this instruction.
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41 or 4F the print head is defective.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If numberis over 6000, enter 2 7 8 3.This will reset the purge count value. Then restart the printer, hopefully without the annoying cannot clean message.
Posted on Nov 02, 2009
Brother mfc-420cn printer envelope jam
If you did not get ALL the jammed sheet out, there is still a small piece of paper in there somewhere, probably covering a sensor or micro switch. Get a torch and look carefully. If you don't find anything you may need to disassemble the printer to find it
May 14, 2009 | Brother MFC 420CN All-In-One InkJet...
Not printing
the you remove the film clear on the front look like cover a little hole ?
Nov 17, 2008 | Brother MFC 420CN All-In-One InkJet...
Apr 09, 2008 | Brother MFC 420CN All-In-One InkJet...
My Printer works fine... except it won't feed business cards or card stock
You cant fix this because brother printers are limited to paper:
paper that weights more than 200g wont run through the paper feeder.
Mar 19, 2008 | Brother MFC 420CN All-In-One InkJet...
My brother mfc 420cn printer won't print
Feb 20, 2008 | Brother MFC 420CN All-In-One InkJet...
Unable to scan with paper feed
Plz name your mfc, your operating system and the country your are from. post it here.
Nov 03, 2007 | Brother MFC 420CN All-In-One InkJet...
Mfc-5460cn
Please tell us what machine do you really have:
Is it a mfc 420cn or a mfc 5460cn?
Did you have a paperjam before getting the error?
This might be due to the paperjam.
Ill try to give you some more help but need more info...
Oct 25, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 420CN All-In-One InkJet Printer Logo
81 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
