Question about Panasonic SC-AK78 CD Shelf System
How do you reset the 5 cd disk?
I keep getting an error message "Disc Takeout". When you push in the door for the cd, it keeps opening up. How do you reset the cd or system? or Clean the cd lens?
Thanks for your help.
  • 82 Answers
Re: How do you reset the 5 cd disk?
Try this to rest unit.With cd selected press and hold 'Stop' for about 5 sec. keep holding then press and hold 'skip FF' for about 5 more sec. Take off power then unplug unit, then power back on. A line shows across the screen if it works.
Posted on Dec 05, 2007
0 characters
3 Points
When I push the cd open-close buttons on the player, the disc tray does not come out. When I select a CD# it says reading, but nothing happens. The player indicates that there are discs in all 3 spaces,...
It is likely worn drive belts. There are 2 within this hi-fi. I replaced my belts with elastic bands. No issues so far.
1) Remove power and unplug unit
2) Remove 4 x lid screws and lid
3) Remove both side panels.
4) Remove silver plate from shielding cd drive
5) Replace belts with 25mm diameter bands
6) Reverse the strip down.
New belts are $6 each on e-bay
Jul 29, 2011 | Philips MC-70 CD Shelf System
CD deck
That means that there is a mechanical error concerning the tray gears
Oct 11, 2008 | JVC UX-S57 CD Shelf System
I have a RCA RS2664B 5 Disc Player and the disc door won't open and you can not play CD'S. Help!!!!!
unplugged the unit for 5-10 mins........ when u plug it back to ac the stop/eject...the cd player by default is trying to load the disk wish to open the disk tray..once all disk are recover try another disk to play
Sep 12, 2010 | RCA Audio Shelf Systems
My RCA Stereo system 5 disc cd drawer keeps opening. When I put a cd in it, the unit opens and keeps opening. It only stays closed when I turn off the unit and manually push it closed. What could be...
These units are actually nice units. There is a "loading belt" inside that controls the tray movement as well as the final "load" of the mechism into the play position. If the load does not complete, the unit will "eject" or open up. This is most often cured by replacing the loading belt. This is a common problem with any rubber component. As it ages, it gets a little slippery and thus will not have the grip to complete the loading sequence. The belt for this will run about $5.
Aug 26, 2010 | RCA 100-Watt Stereo System With 5-CD...
Cd player stop playing... disc, data or it simply keeps searching for the tracks on the cd. How can this be fixed?
Try cleaning the lens with a CD lens disk cleaner, see if that rectifies the problem. Hifi systems are notorious for dust buildup being an enclosed system with an exposed cd drive deck.
May 24, 2010 | Panasonic SC-AK100 CD Shelf System
Cd does not spin
the motor will need to be replaced
Apr 15, 2009 | Fisher SLIM-1500 CD Shelf System
Error message No Disc
Unit has bad disk t-table motor
May 06, 2008 | JVC MX-J200 CD Shelf System
Sharp mini system error code 20
The code CD20 means Tray error. The cd mechanism will have to be reset by a serviceman .
Jan 06, 2008 | Sharp Multi-System Mini Component System...
Fisher tad 5060
the only way to reset a error disc is to unplug the radeo and push air dust the cd mech and lens then push the lens all the way back plug the power cord the, turn on power it should reset itself , i had same problem before and it work.
Nov 09, 2007 | Fisher Audio Shelf Systems
CD malfunction
It sounds like you have put a disc in the tray that the system can not read, so it will just keep trying to read the disc over and over again. If you turn everything off by the plug and wait a few mins the whole system should stop. Put the plug back in and as soon as you turn your system on, try and press the disc open key before the lens gets a chance to start reading it again. If this does not work you may just have a disc jammed. So you will have to get someone to check it out for you if you do not understand what you will be doing, because you may do more harm than good to your system. Good luck.
Aug 29, 2006 | Sharp CDES600 5 CD, 240W, Silver, Mini...
Panasonic SC-AK78 CD Shelf System Logo
389 people viewed this question
Top Panasonic Audio Shelf Systems Experts
Jonathon summesfield
Are you a Panasonic Audio Shelf System Expert? Answer questions, earn points and help others
