Question about Kicker (ZX350.4) Car Audio Amplifier
Protection light comes on at higher volumes. Flawless install and correct gauge wires all around. I sent the amp in for repair as it didn't work brand new and when it came back today I noticed on the comment sheet it said reapired stripped speaker terminal. I know thats not the problem and I'm dissapointed they didn't look any further. My components I'm running are infinity kappa and they use the supplied crossover network. The speakers pull a 2ohm load but this should be no problem for the amp. Any thoughts?
  • 113 Answers
The mosfets in your amp are getting too hot try a 12 volt fan and u should notice a difference right away
Posted on Jul 04, 2009
Sony HCD-GT222 Hi-Fi CD and cassette deck with tuner, suddenly started to shut itself down at volumes higher than 50%, after three years of flawless operation.
It's thermal; protection is happening probably due to bad ventilation. Fuzz and dust can block air vents.These need to be vacuumed out now and then.
Jan 22, 2014 | Audio Players & Recorders
Protection light comes on and volume returns to zero. I am using a Azur 540A. This issue occurs when I ride the volume above a certain point, which is NOT any higher than i've been running it for years....
Protection circuits respond to overloads. Unless the protection circuit is faulty there is probably something wrong with the power amp parts located on the heat sink.
It would be a good idea to have the top cover off (on power) and listen for that noise to try and pin it down what is making it.
Aug 24, 2013 | Cambridge Audio Azur 540A Amplifier
THE PROTECTION LIGHT COMES ON
make sure your ground is drilled threw thick metal and the paint is scraped off and make sure that all the wires connecting the amp are 4 gauge or higher and if that doesn't do the trick get a better amp that can throw more power
Mar 29, 2010 | Lanzar Vibe 1200D Car Audio Amplifier
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Dou .A thumbs up would be greatly appreciated if this answer is helpful to you. protection-light-comes-lv2kkrmxrai4iihdvw4m3np2-2-0.jpg http://www.nitrobmw.com/
Jun 14, 2009 | Nitro BMW-482 Car Audio Amplifier
Bass goes off when i turn up the volume
You need to install a heavier gauge wire to your amp and a capacitor. It works fine at low volumes because there is enough wattage from the battery to power the bass output of the amp but at higher volumes the amp does not have enough power.
Heavier gauge wire supplies more poer, and a capacitor stores a reserve of wattage for the amp to use so that it does not run out while blasting your tunes.
Jun 02, 2009 | Fusion FEW12PK Car Subwoofer
Jl audio 1000/1 low voltage -keeps shutting off at high volume
You should definitely upgrade the power wire to the sub amp to 4 gauge -absolutely your choking your amp its starving for current-poor thing is starving !!!!!!!
Apr 16, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Nad C370
Since the problem seems to be sensitive to the volume level, I would be looking at the output wave form for any DC current. Although the protection circuit should detect any DC present, it is possible that some is leaking through. Also, verify that the speaker impedence is correct. If the amp is seeing too low an impedence load, it will work too hard causing excessive heat which will shutdown the unit as well.
Keep me posted.
Dan
Nov 04, 2008 | NAD C370 2-Channel Amplifier
Protection light coming on and amp cutting off
yes make sure there both connected properly, check the fuses, the protection light usualy comes on when there is too much power and the amp protects itself from blowing
Jul 16, 2008 | Car Audio & Video
Protection Light irritation
If the amplifier goes into protect when there are no speaker wires connected to the amp, the amp is likely defective. The most likely culprit is shorted output transistors. If it's new, return it to the place of purchase for repair/replacement.
Sep 28, 2006 | Lanzar VIBE266 Car Audio Amplifier
Open Questions:
Car Audio & Video Logo
95 people viewed this question
Top Kicker Car Audio & Video Experts
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
