Home | Frigidaire | 20.6 cu. ft. Top Freezer Refrigerator wit... | My refridgerator is lea...
Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker
Problem for Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with...
My refridgerator is leaking water from the front
By mailmot10 on Jul 03, 2009
my refridgerator is leaking water from the front of the refridgerator....i find a puddle on my floor every day.....what could be the problem....and what temperature should the refrigerator be set to....I own a Frigidaire 20.6 top refrigerator
Comments:
Jul 03, 2009
- Where is the drain tube located....is it located in the back of the refrigerator where the coils are...there doesnt seem to be a buildup of ice in the freezer section at the top...so where do I flush it out.
Jul 04, 2009
- I must sound like a complete idiot....I have a Frigidaire P/N 241543903 18.2 Top Mount Refrigerator. I know you said the tube is in the freezer itself...is the panel that I have to remove actually inside the freezer in the back...I tried removing it but it doesnt come off....undeneath the panel is where the controls to the freezer are...Am I looking in the right place
Solution #1
posted on Jul 03, 2009
Not Rated)
woodchuck789
Rank: Guru  Frigidaire Expert Refrigerators  Expert
Rating: 90%, 515 votes
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
The fridge should be 40 degrees on lower but not 32 degrees of course.
Comments:
Jul 03, 2009
- It's in the freezer below the evaporator coils. You may have to remove the back cover to see it. There is no ice build up because your defrost system is working but the ice that gets melted drains into this drain tube which is probably stopped up so the water can freeze in the top of the tube because it's in the freezer.
Jul 03, 2009
- It always helps tremendously to have a model number. You can post it at this side and search for evaporator coil and see the drain pan under it. http://www.partselect.com/PartDetail.aspx?Inventory=2061185&SourceCode=1
Was this helpful?
Yes
No
Popular Solutions for Frigidaire 20.6 cu. ft. Top
Questions and Unsolved Problems for Frigidaire 20.6 cu. ft. Top
Do you recommend Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker?
Answer
Answer
I've got A Roper RT185DKXKQ00 which cools great but when it cycles on you can hear what sounds like... (More)
Answer
my frigidaire refrigerator is filling up with water at the bottom of the frig.
Answer
Our Fridge is leaking from the light area in the back. Why would this be?
Answer
Frigidaire Make. Our Fridge is only about 4 years old. It keeps cutting out and everything thaws and... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Frigidaire 20.6 cu. ft. Top...:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 632
Experience: im jack of all trades but a master of none! and being an old f*rt you get to learn a fair old bit
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
