Pioneer Elite Kuro Pro-151fd 60" 1080p Hd Plasma Television Logo
m
moe saah Posted on Sep 26, 2014
<!-- from fixya rte -->How do i factory reset my TV - Pioneer Elite Kuro Pro-151fd 60" 1080p Hd Plasma Television
Jason Whyatt
Level 1:
New Friend:
  • Contributor 8 Answers
  • Posted on Sep 26, 2014
Jason Whyatt
Contributor
Level 1:
New Friend:
Answers
8
Questions
Helped
2027
Points
20
I have a Factory Mode: P that is displayed permanently on the screen.
We need 'make model (what it is)' as first 3 words in all questions.
Or we can just guess.
What is Factory Mode and how do I disable it?
Philips https://www.usa.philips.com > what-is-factory-mode-a...
Dec 23, 2019 - i. Press [Info] - initiate Factory data reset (Erase all data on TV) · ii. Press [CC] > [HOME] > go to Settings > Storage & reset > Select " ...
Been getting this text over my TV (TCL P8s) Running ...
XDA Forums https://xdaforums.com > ...
Oct 30, 2020 - I'm unable to factory reset after this text started appearing ... It's sita P mode from service menu. You have to stand on contrast in ...
How to fix Roku TCL TV that's stuck on recovery mode screen
Roku Community https://community.roku.com > Discussions > td-p
Nov 8, 2020 - I did a reset by holding the button for 30 seconds and then leaving the TV unplugged for 2 hours. I then did a factory reset from the settings ...
222 answers · Top answer: @rileybutton @Lemons2lemonad Thanks for the post. Can you provide us with a screenshot ...
How to Perform a Factory Reset on an Android TV
TCL Support https://support.tcl.com > us-androidtv-troubleshooting
From the TCL Android TV remote control, press the Settings button; Scroll to More Settings > Device Preference > Reset; Select Factory data Reset on the Factory ...
I have a sonic TV and can't retune, because of a code lock which I don't have
If you have forgotten the code lock for your Sonic TV and cannot retune it, you may be able to reset it back to factory settings by performing a factory reset. However, please note that this will erase all custom settings and data, and revert the TV to its original state.
To perform a factory reset on your Sonic TV, follow these steps:
  1. Turn off the TV using the power button.
  2. Unplug the TV from the power outlet.
  3. Press and hold the power button on the TV for 15-20 seconds.
  4. While still holding the power button, plug the TV back into the power outlet.
  5. Continue holding the power button for another 15-20 seconds, then release the button.
  6. The TV should now reset to factory settings.
Please note that the steps may vary depending on the specific model of your Sonic TV. If you are unsure or if this method does not work, you may want to consult the instruction manual for your TV or contact the manufacturer for further assistance.
Mar 19, 2023 • Cell Phones
How do I reset my AIm 32tv locked no remot
To reset your AIm 32TV without a remote, you will need to follow these steps:
  1. Locate the "Menu" button on the TV: The button is usually located on the side or at the bottom of the TV.
  2. Press and hold the "Menu" button: Press and hold the button for about 10 seconds or until the TV turns off.
  3. Turn the TV back on: Press the "Menu" button again to turn the TV back on.
  4. Look for the "Factory Reset" option: Once the TV turns on, navigate to the "Settings" or "System" menu and look for the "Factory Reset" option.
  5. Perform the factory reset: Select the "Factory Reset" option and follow the prompts to reset the TV to its original settings.
Note that these steps may vary depending on the specific model of your AIm 32TV. It's also important to check the user manual for the correct steps.
If you are unable to find the factory reset option, or if the TV is locked, it may be best to consult the manufacturer or an authorized TV repair center for further assistance.
How do I reset a sony barevia 32ml130 tv without remote
Hi
You can try.
Part 1: Manual Factory Data Reset with TV buttons
Press and hold the Power button and Volume Down (-) buttons on the TV (not the remote), and while holding the buttons, plug the power cord back in. Continue to hold the buttons down until a green LED light appears near the Sony logo on the TV front.
How do I factory reset my Sony Bravia TV manually?"); display: inline-block; height: 24px; width: 24px; margin-top: -1px; transform: rotateZ(-180deg);"> Factory data reset
  1. Press the HOME button, then select [Settings] - [Device Preferences] - [Reset] - [Factory data reset].
  2. Select [Erase everything]. If you have set a PIN code on your TV, you will be prompted to input it when you select [Erase everything].
How do i Reset sony kdf55wf655 without remote
To reset this set to its factory settings:
Press when in a Menu, to reset the settings to the factory defaults. Also user to clear Labels, Channels or Favourite Channels.
To reset the TV fully to its Factory Defaults:
Turn ON the TV while Holding Down the "RESET" button on the remote control, Press the POWER button on the TV. The TV will turn itself OFF, then back ON again. Release the RESET button.
2answers
Onn tv factory reset
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
How do i reset a sony wega kdf55wf655 tv?
Hello
Turn ON the TV while Holding Down the "RESET" button on the remote control, Press the POWER button on the TV. The TV will turn itself OFF, then back ON again. Release the RESET button. OK.
4helpful
Samsung Le40a556 factory reset
with tv in standby press INFO / MENU / MUTE / STANDBY on remote the tv will come on in factory menu settings look for reset use DOWN NAV KEY until highlighted and press RIGHT NAV KEY
to exit settings press standby the tv will come on and follow on screen instructions
DO NOT CHANGE ANY OTHER SETTINGS TV WILL NOT WORK IF CHANGED
1helpful
Factory reset Menu
IF A SAMSUNG TV Put tv into STANDBY
WARNING DO NOT CHANGE ANY OTHER SETTINGS TV WILL NOT WORK
Press INFO / MENU / MUTE / STANDBY on remote tv will come on with service menu displayed and FACTORY RESET (12) is on it
ONLY USE DOWN NAVAGATION KEY until you highlight factory reset
NOW PRESS RIGHT NAVIGATION this will reset all settings
PRESS POWER ON THE TV TO EXIT then turn on tv and retune
Top Pioneer Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
