Question about NetGear RangeMax WPN824 Router
Signal range is very poor - NetGear RangeMax WPN824 Router
  • WiFiNut
    WiFiNut May 11, 2010
    Do you have the ability to change either your data rate and/or signal power output in mW?
  • 1,272 Answers
For poor signals, please change the wireless channel on the router by logging on to router configuration.
Try updating the firmware on the router as well.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Posted on Jul 04, 2009
I keep losing connection to my Wifi Extender
Apple have produced a downloadable app for managing this router.
It also acts like a signal strength meter, and can control various modes on the extender.
Check there is not a scheduler or "Good Night" setting on the extender.
EdiRange
Signal indicator
Amber
Flashing
Poor signal strength:
0 - 39%
So your problem is still poor signal strength, your extender is still not within the wireless range or your router.
See Manual.
http://us.edimax.com/edimax/mw/cufiles/files/download/manual/transfer/Wireless/EW-7438RPn_Air/EW-7438RPn%20Air_manual.pdf
Aug 19, 2013 | Edimax Network EW-7438RPN Wireless N 300M...
Poor signal with WiFi on my zeepad
Having a wireless Internet signal in your home allows multiple devices to use the same Internet connection without having to run lengths of Ethernet cable to each device. Given that the wireless network is transmitted over the air, the consistency of your Internet connection depends on the strength of the wireless signal. If wireless signal strength is not strong enough to give you a consistent Internet connection, there are a few simple steps for finding the problem and improving your signal strength.
Reset all devices. The majority of Internet issues, including poor wireless signal strength, are very often solved by a simple power cycle of all the devices in the network. Locate the power cords of both your modem and your wireless router and remove them (if you use a modem/router combination, simply unplug the power to that device). Leave them unplugged for a full 30 seconds, plug them back in and restart your computer. When your computer fully reboots, check your wireless signal strength to see if it has improved. If it has not, further troubleshooting is required. Move your computer closer to your router, or your router closer to your computer. Wireless routers do not have unlimited range. One reason your computer may be getting a weak signal strength from your wireless network could be because your computer is simply outside of the router's range. Typically, ISPs (Internet Service Providers) will install your modem in one specific location in the house and the modem will not work at other locations, so moving the modem or modem/router combination may not be a possibility. If this is the case, you may need to move the computer to a location that is within the range of the wireless router's broadcast. If you still get poor signal strength, your router may be experiencing a malfunction. Contact the technical support department of your router manufacturer. Router malfunctions often are not the result of a bad or broken router, but of something much simpler, such as the router's needing a firmware upgrade or an incorrect setting on the router's internal setup. If your router manufacturer is unable to improve your wireless signal strength, it may be time to purchase a new router. Purchase a new router. Wireless routers are priced in part based on how widely their wireless signal broadcasts (in other words, the more expensive the router you buy, the larger a wireless signal the router will broadcast). Included in the packaging of each wireless router is the approximated range, in square footage, of that router's wireless network. A good rule of thumb is to know the square footage of your house and buy a router that can accommodate that square footage. That way, as long as the router is functioning properly, you will have strong wireless signal strength throughout your entire home. Hope this helps.
b>
Dec 13, 2012 | Computers & Internet
Code P0706 transmission control module repair cost
You just don't throw a part on, If the problem is the transmission range selector switch (not the control module) the cost to repair will be around $250.00
P0706 AUDI - Transmission Range Sensor Circuit Range Performance
Possible causes- Open or short park/neutral position switch circuit
- Poor park/neutral position switch circuit connection
- Misadjusted park/neutral position switch
- Park/neutral position switch may be faulty
When is the code detected?The transmission range switch detects the selector lever position and sends a signal to the TCM.
Sep 18, 2012 | 2006 Audi A4
The signal range of the wireless of my Edimax br6204Wlg isnt working well. One of these days i turned it on and the signal was really poor, i just could get it with my laptop at the side of the router, and...
At this point, replace the router. I suggest a asus rt-n12 router. It a decent router for a good price. It also allows you to flash it with a firmware called dd-wrt, which turns it in to a very stable high end wireless router.
Jul 22, 2011 | Computers & Internet
Hard to start running rich & stall
Sounds like a MAP inlet Manifold Absolute Pressure sensor fault. Symptoms of a faulty MAP
  • Poor starting/erratic idling/engine stall - with the MAP not sending the correct inlet air pressure signals to the ECU, incorrect fuel injection volumes then result. The imbalance in the fuel/air ratio often leads to rough engine performance and poor starting and stall. The engine might be kept running at start up by pumping the accelerator pedal
  • Sluggish performance/power ceiling - the engine may seem to perform normally in the lower rev range but will severely run out of power above about 3000 rpm
Poor fuel economy. The ECU tends to supply an over rich fuel mix to the engine in the absence of signal from the MAP resulting in very poor fuel economy. The reason for this is that if the MAP has no signal this ECU assumes 'no vacuum' = fully open throttle = engine is under load. To match this 'open throttle' signal the ECU increases the injection cycle to supply more fuel
How to Check? The MAP has three electrical pins, one for 12 volts (or 5 volts) reference, one for ground and the third (the middle one generally) is the 'signal' output. Put a voltmeter positive connector on the 'signal' pin of the connected socket (back probe by inserting a bit of wire). Apply suction to the vacuum input, even sucking on it with your mouth, should result in a measurable voltage output. At normal air pressure (open throttle) the voltage seen should be 0 volts. As vacuum is applied the voltage output should change to about 5 volts (throttle closed at idle). If no transition seen the MAP is faulty.
Feb 02, 2011 | Chrysler Sebring Cars & Trucks
Jaguar xj6 4.0 1990. showing fault code fuel 14, fail 14. what does this code mean ?
2 airflow sensor out of operating range 3 coolant temp sensor out of operating range 4 oxy sensor indicates full rich 5 throttle potentiometer/airflow sensor... (low throttle pot signal with high airflow sensor signal) 6 throttle pot/airflow sensor...... (high throttle pot signal with low airflow sensor signal) 7 throttle pot...idle fuel adjustment failure(idle speed??) 8 intake air temp sensor...open or shorted circuit to sensor 11 Throttle pot at idle: Throttle pot idle trim out of normal range 12 Airflow meter: MAF signal out of range 14 Coolant thermistor: Resistance out of range or static during engine warm up 16 Air thermistor: Resistance out of range 17 Throttle pot: Out of range 18 Throttle pot/Airflow: Low throttle pot signal at high airflow 19 Throttle pot/Airflow: High throttle pot signal at low airflow 22 Fuel pump drive: ECU output to fuel pump relay 23 Fuel supply: Engine running too rich 24 Ignition Drive: ECU output to ignition Amp 26 Air leak: Engine running too lean 29 ECU self check 33 Injector Drive: ECU output to injectors 34 Injector: Looks for Injector dribble 37 EGR Drive: ECU output to EGR switching valve 39 EGR check sensor: EGR not working (normally pipe blocked) 44 Lambda (O2) sensor: Poor mixture control rich or weak (or misfire) 46 Idle speed Control valve: ECU output to Coil AB 47 Idle speed Control valve: ECU output to Coil CD 48 Idle Speed Control Valve: Stepper motor grossly out of position 66 Air pump: ECU output to air pump relay 68 Road speed sensor: Seen speed < 5km/h at high engine airflow 69 Drive/Neutral switch: Seen cranking in "D" or high airflow in "N" 89 Purge Valve drive: ECU output to purge valve
this is all I could find
Nov 09, 2009 | 1990 Jaguar XJ6
Poor Wireless Printer Connection
Yes move the printer closer to the router or vice-versa, or make sure their are no microwaves between the router and printer. Chordless phones, thick mason or plaster walls can also hurt the signal range...Good Luck
May 03, 2009 | Canon PIXMA MP600R All-In-One InkJet...
Range is very poor
You need to change the wireless channel of the router. Access the router's setup page through http://192.168.1.1, no username, password is admin. Go to wireless tab, Select Manual Setup, change the Radio band from auto to Wide Range. Also change the Wireless network name to a different name then click on save settings at the bottom. Power cycle the router, unplug it for about 30 sec then plug it back in.
Jan 19, 2009 | Linksys Wireless-G Broadband Router
Poor wirless signal
Hi HHC,
You can try resetting the Westell to defaults, but pressing a thin pin, (Paperclip works great!) into the reset hole, in the back, and holding it in for 10 sec. You could also try using the lowest channel you. Most Westell's I have worked with have good wireless range, though. Test your laptop at a nearby hotspot, i.e. Starbucks. McDonalds, etc. If it is not the laptop, (Averatec laptops have horrible range!) and the reset don't fix it, have it replaced.
Good Luck!
Jan 07, 2008 | Westell Wirespeed VersaLink...
NetGear RangeMax WPN824 Router Logo
157 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
