Question about Insignia Audio Players & Recorders
Insignia ns-r5100 shuts off when volume is barely at a high level
The only speakers i have hooked up to this receiver are two 8ohm bookshelf speakers. when the volume is up not even half-way, the receiver will shut off. like if i watch a dvd and there is a gunshot, the receiver will shut off. this doesn't seem to be normal and it's really quite frustrating. i'd like to return it, but it's over a year old now. perhaps this is a common issue with this receiver and Best Buy will fix it or replace it? any help or suggestions would be appreciated. thank you.
noah
2 Suggested Answers
SOURCE: Insignia NS-R5100 5.1ch receiver shuts
the output transistors are blown in one or more channels also the driver transistors are blown in the same channel.
you can find this problem real easy using a DVOM (digital volt ohm meter) on the continuity test(BEEP).
start be removing the amp section from the receiver and laying it on the table bench whatever no going from B-C and C-E if any beeb there junk and the driver transistors are also and there are a few resistors that are junk.
parts list
2@2sd2390 sanken get from newark and only newark/farnell
2@2sb1560 sanken get from newark and only newark/farnell
2@2sd947 from newark
4@ 2sc1841 or 2sc1845 to replace 2sc1845
4@ 2sa998 or 2sa992 to replace 2sa992
8@ .22 ohm 1/4 watt metal film resistor 1%
2@ 4.7 ohm 1/4 watt metal film resistor 1%
this is a parts list for 2 channels
only get the powertransistors (the sanken) from newark any others i have found as counterfeit and destroy stuff and dont work
i dont remember location #'s on the board but
Posted on Mar 17, 2010
My Insignia NS-R5100 receiver goes into standby mode a couple of seconds after turning it on.
This happens because of internal overheating - clean the air vents and if you have covered the receiver with a cloth please remove the cloth your problem could be resolved
Jun 21, 2015 | Insignia Audio Players & Recorders
Can I use 2 - 4 Ohm speakers on my Insignia NSR2001 AM/FM Stereo Recever
Yes. You can. But the volume level should be adjusted. Never use it very high, as it might damage either the unit or the speakers.
Oct 29, 2014 | Insignia Ns-r2001 - 200w 2.0 Channel...
NS-R5100
Probably a short in the amp that will need to be repaired.
Feb 27, 2013 | Insignia Ns-r5100 Av Digital Home Theater...
I have a Sony CDP-CX355 300 CD Player and old Technics SA-5060 receiver and two new Insignia NS-B2111 bookshelf speakers, with old but solid speaker wires. When playing the CD player, loaded with symphonic...
Don't run anything but a TURNTABLE through Phono. That's the only labeled input that's literal. Use any other Line Level input for the CD.
If you don't have anything connected to the Tape loop, use the Tape In connectors.
Feb 18, 2011 | Sony MegaStorage CDP-CX355 300-Disc CD...
I get my receiver to about 65% volume and it turns off
Check the ohm load for the reciever, then check to see what ohms are of the speakers. make sure they match. 4ohm to 4ohm, 8ohm to 8ohm. If unit feels hot when it shuts off, it's a themal overload, put in to keep the reciever from getting damaged. It comes back on when cool right? Overload could be on its way out and shutting down at a lower temp too
Jan 05, 2010 | Yamaha RX-797 Receiver
Receiver shuts off when you turn up the volume.
your safety overload circuit is kicking in and prenting the amp from shorting. you have a bad speaker most likely or horn. try operation it with headphones next. try bookshelf speakers at a moderate level to test if it persists then the amp has a biggger problem.
Dec 08, 2008 | Pioneer VSX-815-K Receiver
Avr 3806 power shuts off when volume turned up
Hello david 420
It looks like your receiver's high-speed protection circuit is being activated. It is definitively not a fuse. When a fuse pops, you have to physically replace it. When the protection circuit is activated, the speaker output is cut off and the power supply indicator flashes. There are a few reasons why this happens:
1.- Your speaker wire connections are loose. Whether they are banana plugs or bare wire ends, make sure the speaker terminals on the back of your receiver are tight using clockwise turning.
2.- Verify that your speakers have an impedance between 6 and 16 ohms. Your receiver was designed to work with that impedance range. Any impedance lower than 6 ohms will activate the protection circuitry.
3.- The receiver is used at high volume levels over a long period, which results in an
extreme temperature rise. Improving the ventilation conditions around the unit might help alleviate the problem.
If after complying with these suggestions, problem is still present, you might need to have the unit checked by a professional for possible circuit failure.
Hope this helps. Let me know.
cancerags
Dec 31, 2007 | Denon AVR-3806 Receiver
Onkyo 705 receiver shuts off at higher volumes
I had this same problem and it turned out to be a twisted kink in the speaker wire. Run a sound check to each speaker separately (from your receiver menu) and turn each one up until the receiver shuts off. Check the wire to the speaker that caused it to shut off and make sure the +- ends are not touching each other at either end, and that there are no twists or kinks along the way.
Nov 04, 2007 | Audio Players & Recorders
Unit going into protection mode
You should first have or check the impedance and resistance of the speakers. then if all the speakers and wiring checks good, the only way to tell if this unit is good or the output section has no problems, is to hook up load resistors to where the speakers go, insert 400 to 1000 hz @.775MV into an input, hook up an osilliscope to the load resistors and slowly turn up the volume and see if the waveform clips before it shuts down. I doubt if you will have the equipment to preform these test but a good repair shop will be able to help you out. If it does not clip or go out then its all speaker wiring and/or the speakers.
Oct 04, 2006 | Sony STR-DE575 Receiver
70 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
