Question about Refrigerators
Th compresser is burnt out my refrigerator is only 6 years old
  • 4,070 Answers
Since warrentys are for 5 years you have to decide weather to but a new fridge/freezer or pay a tech to replace it, which can be expensive. Call for estimates. That is not a do it yourself job.
Posted on Jul 03, 2009
What does it cost to have compressor replaced 5 year old refridge
You are usually looking at $500-$800 depending on who is going it. For a buring smell I would first look at the condenser fan motor seizing up. If it is running properley then the relay on the compresser may have burnt up in which case you can install a 3in1 hard start kit and see if you can get the compresser to run before spending money to replace it. Good luck
Sep 09, 2012 | Maytag Refrigerators
The TV just shut off and won't turn on, only a year and half old panansonic th-42px80u
Usually when TV sets just go off and refuse to come on it usually is a problem with the power unit of the set. Would be best refered to an expert to help trace the exact conduit which is burnt. Should just take a little replacement of a conductor and you set will be working fine as before.
Hope this solution has been helpful?
Nov 28, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
We have a amana refrigerator that is 6 years old and i was told the compresser went out. Should that happen to a 6 yr fridge?
The compressor is an electrical device and then can fail at any time....there is no reliable way to totally predict the life span... power surges and power conditioning can also affect the reliability of the device....
If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 20, 2010 | Amana ABB1927DE Bottom Freezer...
Electical module to compresser burnt out
That is the compressor start relay and klixon. This happens most of the time when a unit os several years old due to the contacs on the relay and klixon getting loose from heat which causes more heat and then results in a failure. It can also happen when the compressor itself fails to start due to a failure of the compressor. The Klixon is a tthermal protector that controls a start winding period It heats up and then opens the circuit if the compressor does not start.
You did not mention any symptoms prior to your discovering the burnt electrical module so I am assuming there were none visible inside or out.
It is worth the effort to have this checked out by a qualified repairman. Many times it is as simple as replacing the start realy and klixon (interlocked as an assy when installed) Other than the service call and labor the parts required to attemot repair of this unit are less than $50.00. Once again it is worth an initial attempt at repair if the unit is less than 8 years old.
Jan 04, 2010 | GALAXY Microsystems 25.4 cu. ft....
My refrigerator is 24 years old. Yesterday it stopped working, both the freeser side as well as the refrigerator side. I hear the engine still running but neithr sides are cold. Is it dead??
Possibly since it is an old system the compresser could have got locked up since it is so old. Especially since there is no cold on the evaporater.
Aug 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Th compresser is burnt out it had a clicking noise then it started smelling
The clicking noise is usually the starter relay. Unless you're sure the compressor is bad,which is not a do it yourself job, Check your compressor relay- http://www.acmehowto.com/howto/appliance/refrigerator/check/compressorrelay.php
Jul 03, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Frigidaire side by side ice maker, water and ice dispencer inop
It would depend on the age of the refrigerator whether repair is economical. If the refrigerator is under ten years old repair it. If it is over ten years old you have to consider how much life is remaining for the refrigerator. Burnt smell source must be located because that is the key to your problem. It could be a simple matter of replacing the switch in the door.
Jul 05, 2008 | Refrigerators
Frigidaire refrigerator
check the overload, take it loose and inspect it for a burnt spot shake it if it rattles replace the relay
you either have a relay bad or a stuck compressor
the compressor has a 5 year warranty on the part, the relay 1
so if you relpace the relay and it still doesnt run the compressor, call for serviece under warranty
Apr 27, 2008 | Frigidaire FRS26R4A Side by Side...
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
