v6 engine not told,
let me guess that.
ok easy v6 means 3.7 L (226 cu in)
magnum v6
I have 3.7L in my jeep.
mine is 2010
the service manual covers all this, buy it or rent it?
not told which bank needs offing/ left or right.
well all engine work here, is top down, and what you see in the way must come off
but not told the goal, ??remove the valve cover,you never said that.
just disconnect or remove to get to it( just touch the cover that?)
just use a hand stethoscope.(held to all places there)???????????
the service manual , this page, called rockers covers.
asks LEFT or RIGHT first ,so I toss the coin and land on left drivers side
USA left, is LHD driver. side
- Disconnect negative cable from battery.
- Remove the resonator assembly and air inlet hose.
- Disconnect injector connectors and unclip the injector harness.
- Route injector harness in front of valve cover.
- Disconnect the left side breather tube and remove the breather tube.
- Remove the valve cover mounting bolts.
- Remove valve cover and gasket.
now right.(called in USA LHD , passenger side)
RIGHT SIDE
- Disconnect battery negative cable.
- Remove air cleaner assembly, resonator assembly and air inlet hose.
- Drain cooling system, below the level of the heater hoses.
- Remove accessory drive belt.
- Remove air conditioning compressor retaining bolts and move compressor to the left.(tie it back gently) no hoses OFF !!!
- Remove heater hoses.
- Disconnect injector and ignition coil connectors.
- Disconnect and remove positive crankcase ventilation (PCV) hose.
- Remove oil fill tube.
- Unclip injector and ignition coil harness and move away from valve cover.
- Remove right rear breather tube and filter assembly.
- Remove valve cover retaining bolts.
this answer is for only removal
to just touch it , is between step 1 and what ever it takes to do you you never told yet.
or use youtube, how to remove cylinder heads, so see all steps
to where you want to be. (less sure)
