Question about Kenmore Refrigerators
Water comes out of the water dispenser in a trickle. Side by side model, icemaker in the door. Water filter was just replaced; water was only coming out in a trickle before replacement. Model 106.57033602
    Problem Solver:
  • 16 Answers
Sounds like the solinoid valve in the back of the fridge is not closing all the way.usually located at the the bottem right. replace the valve. It will have a 1/4 inch plastic hose line attached to it. shut off the water source first, then remove the valve, be sure to write down the model and serial number before you go to a appliance shop.
Posted on Jul 03, 2009
After changing the water filter, the ice maker is not working. The water dispenser is working properly.
You may need to replace the dual water control valve due to only the water dispenser side of the water control valve being the only side that works. What is the model number of your Kenmore refrigerator? Kenmore model numbers look like this=> 321.235689 as an example. An example of the water control valve if your model number was 321.235689 is part number=> 12001414 Water Inlet Valve
Don't use this example as the correct part. Look around the fresh food section door frame for your correct model number, Thanks
Sea Breeze
Testing the Water Control Valve
Mar 31, 2013 | Kenmore Elite Side By Side Refrigerator -...
I have a kenmore side by side icemake & filtered water and their is no water coming out now.
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer. . GE makes a heater that will prevent this from happening again. The part number for this heater is WR49X10173.
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad
Feb 03, 2011 | Kenmore 53642 / 53644 Side by Side...
Water is not dispensed but icemaker is working
It's more common to be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws
If it doesn't come out then disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If the water comes out then check the reservoir.It's behind the crispers in the fridge.
Sep 07, 2009 | GE GSL25JFPBS Side by Side Refrigerator
No Ice is being made
Ice maker solenoid ...side..water side ok replace
Aug 18, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water is dispening to slow
check for proper flow and pressure on water supply line
Feb 23, 2009 | KitchenAid Superba KSCS23IN Side by Side...
Slow water coming out od water dispencer in door.
first off replac ethe water filter in the unit this will slow down the flow
Feb 15, 2009 | Amana ARSE66MB Side by Side Refrigerator
Icemake not making water
At bottom hinge of freezer is the water line to door. Undo connection in line. It may be a quick connect. To undo push in on one end flange to release, and pull out line. Put bowl under end from under refrigerator and make sure doors are closed. Now push water dispenser and see if water comes out line. If it does, the line is frozen in the door. They had some models that had air leaks in freezer door. This causes insulation to freeze and water line freezes. Push in on inside of freezer door and see if it sounds like snow crunching. If it does it's probably frozen. Also peel door seal back a bit and see if is held on by numerous screws. If it is, it may be one of them that freezes. Call GE. They may still have the program going where you get 2 new doors free. Give them your model and serial numbers.
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
104 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
