Brother mfc- 665cw, everytime i try to open my received faxes folder, the message "The Brother FAX RECIEVE program must be started for you to receive PC Faxes" appears
From the Brother web site.
Description of Problem 100000018247
When I launch PC-Fax Receive Program, I receive an error stating: The Fax Receive program must be started to receive PC faxes. What can I do?pc fax rx
Description of Solution 200000023257
You may receive this error if the pc fax application is closed and you have faxes stored in the memory of the machine. To resolve this issue,you will need to print the faxes already stored in the memory of the machine. To print the faxes, please follow these steps:
1. Press the MENU key.
2. Press the UP OR DOWN ARROW key to select Fax.
3. Press the OK key to confirm your choice.
4. Press the UP OR DOWN ARROW key to select Print Fax.
5. Press OK.
6. Press the BLACK START key.
- Your Brother machine will print the stored faxes.
7. Press the STOP/EXIT key to exit the menu.
8. Once the stored faxes have been printed, click WINDOWS/START, (ALL) PROGRAMS, BROTHER, XXX-XXXX (X = MODEL NUMBER), PC-FAX RECEIVING, XXX-XXXX or RECEIVE (depending on your operating system).
9. The Brother PC-fax receiving icon will now appear in your Windows Task Tray indicating that Brother PC-Fax Receiving is active.
There are a few brilliant hacks that can easily fix your printer bug. Go through the steps below.
Try to restore your computer-By restore your system, you can simply fix the bug.
Update the BIOS-By updating the BIOS, you can solve the problem. The attempt to print again.
Check network connectivity-check the connectivity to the network and restart your printer.
Update or reinstall the printer driver-Your printer driver can be updated or reinstalled to solve the problem.
Run the troubleshooter-To fix the bugs, you can run the troubleshooter. In this case, go to device administration and run the troubleshooter.
Delete your printer software-If you can't solve the bug even after running the troubleshooter, then you can try deleting your printer software.
https://www.brotherprintersupport247.com/blog/resolve-brother-printer-error-state-windows-8
