D-link 615 connects to computer, and creates network, but no net.
I followed the setup CD to the letter, however, it simply doesn't connect to the internet. It does however actually create a wireless network. My modem only seems to flash the internet light when it's connected to my pc, but not to my router.
    Scholar:
  • 40 Answers
Most likely need to reset your modem.
Unplug and plug back in on most models, however the VOIP modems, ones where your cable internet and phone run through the same box usually have a battery, thus you will need to look on the back for a small button that must be pressed with a pen or pencil. Push the button. This will reset your modem and should get you online.
Posted on Jul 03, 2009
Cant connect to d-link DIR-615 wirelessly, can someone help me?
What is the operating system on your laptop?
Can you access the Internet if you connect the computer to the router with the Ethernet cable?
If the wired connection is working then it must be the problem with the wireless network.
If the wired connection is also not working then you may need to reset and reconfigure the router.
If only wireless is not working then you can try creating a new wireless network and then connect your laptop to the new wireless netwok.
I can suggest you a website which may help you for Home network connection.
May 20, 2012 | D-Link DIR-615 Wireless Router
The router installs fine on one lap but I still can't connect my other laptop
your first option is to go to http://192.168.0.1 Here Select admin from the drop down menu and leave the password field Blank.
Once the page loads youll see a series of options. this is the routers linux interface section. you will see D-link on the top left.
Select the first option Install router.
the steps would be as follows.
Step 1.
Insert the Router Setup Wizard CD in the CD-ROM drive. follow The step by step instructions. Once you done this And i believe you have already. see step 2
Step 2.
Select the Option
Setup on the Top > Internet is on the left side.
Under the Internet connection Wizard Hit the Setup Wizard button.
Step 3.
Now on the Setup page Same place where the setup Wizaed is. just below their is another option called Wireless Security Setup Wizard.
Press the Launch Wireless Security Setup Wizard Button.
Read the 3 steps then click the next button to continue.
Steps for step 3.
1. Enter a SSid this will be the network name you see when you want to connect to your own network. example.. MyHome
2. Select your security option then click next. (For simplicity chose WEP)
3. click apply.and let the router reboot.
when it comes back online you should see your network you just setup. our example was MyHome.
If you are new to router setup. use the Wep security called Good on your routers security WEP. and just write the key it gives you down. this is the code you need to connect your devices and is considered ok for a simple home network.
Nov 22, 2011 | D-Link DIR-615 Wireless Router
I have dish network and a dvr and cd disc changer i need to hook up to my kenwood vr-615
Hi shelleyhelle, I was reading over your post and see where you want toconnect the CD disc changer and you want to connect it to the Kenwood VR-615. Iwill send this link, http://www.retrevo.com/support/Kenwood-VR-615-Receivers-manual/id/480bh228/t/2/and it will help with the setup for the Kenwood VR-615 receiver.
Jan 23, 2011 | Kenwood VR615 Receiver
How do i connect router to motem to enternet
The manual, which goes step by step through the setup, is at the following link:
http://static.highspeedbackbone.net/pdf/D-Link-DIR-615-Manual.pdf
Nov 08, 2010 | D-Link DIR-615 Wireless Router
How do i install my D-Link router DIR 615 if i los my cd?
To configure the wireless router, connect a LAN cable from the router to your computer, open a browser and type in the router's configuration URL IP address. http://192.168.0.1
login = admin
PW = blank (just press Enter)
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Mar 10, 2010 | D-Link DIR-615 Wireless Router
How do I get my encription code for my DIR-615, please ? Reset does not work. CD does not work. I spent 58 minutes with Tech help - waste of time and money
If you did the "reset" correctly, the router should have been reset to its "factory" settings.
If so, then connect an Ethernet cable between your computer's network-port and one of the LAN ports on the router.
Access the router's built-in web-server, and run the "Wireless Networking Setup Wizard", to configure the wireless networking, including choosing an SSID, and choosing an encryption-level, and choosing a password for your wireless network.
Jan 14, 2010 | D-Link DIR-615 Wireless Router
I have DI-604 in line between Windows Vista computer and cable modem. Works fine. Bought DIR-615 (wireless). Several places instructions say, ""Insert the DIR-615 CD into computer and click Install Router....
Contrary to the many warnings not to install the router before starting the installation with the CD, I got the installation to complete only AFTER I installed the router inline thusly:
1. Power everything off.
2. Remove DI-604.
2. Install and connect 615 router to computer and to modem.
3. Apply power to router and modem.
4. Apply power to computer and wait until Windows loads.
5. Insert 615 installation CD.
6. Follow the directions.
Nov 22, 2009 | D-Link DIR-615 Wireless Router
Connection, via D-Link Dir 615, lost after restarting computer
Did you tell Vista to "automatically connect to XXXXX network whenever in range" ?
Oct 20, 2009 | D-Link DIR-615 Wireless Router
What are the step for setting up you computers to a network using a Linksys router. I have a 2 PC's and a laptop that I would linke to net work together. My first computer is connect to the Wireless-B...
Hi Ed, if your using windows you can open network connections & run network setup wizard. Follow the instruction for a home network for the wireless PC's & notebooks. Once the network is setup for all PC's than you can install the printer cd software in the PC's that you want to access the printer. Each PC & notebook will have access to the printer through the network.
The PC that that is connected to the printer needs to be shared.
Open printers and Faxes. Right click once on the printer & left click sharing. Agai follow the instructions.
Lastly,I strongly suggest you setup security for your wireless. If you do not anyone close can tap into your network connection. Follow linksys instruction to setup security. If you run into a problem you can call linksys for free advise from a pro. Their number is listed in the manual.
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C1&childpagename=US%2FLayout&cid=1175238819816&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=1981627773H10
Good Luck! Take your time.
Have more questions, feel free to ask.
Mike
Apr 04, 2008 | Computers & Internet
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
