Home | PC Laptops | A15-s1292 wont power on....
PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
A15-s1292 wont power on. screen is bla...
By jackbender on Jul 03, 2009
a15-s1292 wont power on. screen is blank. left hand led is flashing when battery or power supply is installed. no other indiations visual or aural.
Solution #1
posted on Jul 04, 2009
Not Rated)
benwabnick
Rank: Guru
Rating: 88%, 715 votes
Make sure only the ac adapter is hooked up and see if you get video that way.
If not then go ahead and turn off the laptop. Unseat and reseat each memory stick into each slot one at a time in each slot one at a time and try to power it on with each memory stick reinsertion.
This will let you know if either of the memory sticks are bad or if either of the memory slots are bad.
If that doesn't work then try taking out the hard drive and see if that works. Last chance then would be the dvd drive.
If you still don't get any video at this point then the problem is a bad motherboard more then likely cause that means its not seeing any of the memory or the CPU.
Was this helpful?
Yes
No
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
I currently have a Compaq CQ50-139WM laptop. I use CompuHost for doing karaoke shows and the program... (More)
Answer
what is the most affordable but good quality?
Answer
won't boot. all I get is a blinking cursor on a black screen.
Answer
hp dv9000 has a black screen. powers up fine. Start using it in any program and within less than a... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For PC Laptops:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 419
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
