Question about Kirby Heritage II Vacuum
Motor dying? recently my herritage has been sounding sick, i tried to use it the other morning and it barely could blow up the bag, there is also a hot smell to it when it is running, the motor doesnt sound as powerful as it use to. Any suggestions?
  • 357 Answers
Re: motor dying? - Kirby Heritage II Vacuum Vacuums
Replace the carbon brushes in the motor.
Posted on Nov 14, 2007
0 characters
3 Points
Oreck vacuum is blowing out air and not sucking up dust. Why is it doing that???
Most likely the air passage from the motor to the bag is clogged.
Take it outside, remove the bag, and turn it on. That may blow the clog out. If not, open it from the bottom, and try to snag the clog out.
May 14, 2015 | Oreck Vacuums
My Vacuum is actually shooting out debris rather then pick it up. I don't what is wrong but the vacuum is making a really loud wining sound from the motor. Would it be the motor? Will I have to buy yet...
This happened to my vacuum also. I used it this way for quite a while, starting at one end of the room and "blowing" the dirt behind me as I went and then used a broom and dustpan when I got to the tile floor.
The problem was fixed the next time I changed the bag. Apparently, my husband had put the bag in backwards! hahaha Easy fix! :D So, check to make sure the bag is installed correctly!
var fctb_tool=null; function FCTB_Init_8a84e8d3763141509885ba605a550304(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_8a84e8d3763141509885ba605a550304(document['FCTB_Init_f78ff4b269924f65ab55b8367ba4e5df']); delete document['FCTB_Init_f78ff4b269924f65ab55b8367ba4e5df']
May 02, 2011 | Eureka 5849A Boss Bagless Upright Cyclonic...
My Kirby seems to be putting more dirt on the floor than what it is picking up? The brush roller is turning but it leaves dust streaks . It also shoots particles out the side instead of vacuuming it up....
Hi there. It sounds like you belt may be stretched. Simple turn vac upside down, start it up and carefully press your hand on the brush. If the belt is stretched the rollewr will stop turning. If this does not help, you probably have a clog in the power head area. Hope this helps, Chris
Feb 09, 2011 | Kirby Ultimate G Bagged Upright Vacuum
Motor makes loud racket and smells like burning, but still works.
Bag? There is a paper filter and maybe a foam filter ... bag? Maybe this is a newer model that I am not familiar with. Anyway ... ...
It sounds like your motor has been eating dust. Please check here for your repair:
Feb 21, 2010 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Kirby g2000 not picking up dirt
It is most likely the belt. You cannot reverse the suction. First check to see if the bag is expanding when running. If the bag is blowing up then it is the belt if not it is clogged just take the bag off from the vacuum and remove the head you will see the obstruction.
Dec 16, 2009 | Kirby G6 Bagged Upright Vacuum
I have a 10 year old AirVac central vacuum system that has worked until this morning. As I was using it this morning, and turned it off for about five minutes it would not start again. The tank in the...
Sounds like the motor finally siezed on you. Motor is trying to turn but won't thus the hum. Do not allow the vacuum to stay on like this as it may cause a fire. Requires a motor replacement.
Nov 23, 2008 | M&S Systems ZX7000 Bagged Central System...
Blows dust and dirt out of brush area
Did you make sure to cut all the strings, hair, etc. out of the brush attachment on the bottom? Look in the corners too to make sure none has gotten stuck on the sides that needs to be cut out.
Jun 03, 2007 | Kenmore 25812 / 25813 Progressive Bagged...
Check all airways ,it is clogged somewhere. 1 take off the emptor 2check the flexable fill tube in side the bag 3 look inside the casting where u took the emptor off 4 run the machine without paper bag - there should be a free flow of air-LOTTS-u need the emptor back on to do this-keep your face away incase something comes rushing out Cheers Phil C
May 11, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Vacuums Logo
109 people viewed this question
Top Kirby Vacuums Experts
Mike Cairns
Mike Cairns
Roger Potts
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
