the bearings are not toyota specific but are generic for the alternator manufacturer
Pull the unit apart and take the bearings to a bearing supply shop ( CBC , Timken etc) and the numbers on the bearings will identify them
You may get the numbers from an auto electrician who repairs alternators but it would be better to have the auto electrician recondition the unit completely
That way you will have a warranty and a serviceable unit
I found an online reference to that number as from Barry Grainger Ltd, Insurance Brokers, 20 Chapman Way, Tunbridge Wells, Kent, TN2 3EF. A local alternative number shows as 01892 619 688
Battery Light usually means the alternator is not charging correctly and needs to be replaced. Check charging volts, it should at 14 volts or very close to that number. If the number is low below 12 then the alternator needs to be replaced.
Note: A bad alternator can damage the battery & vise versa
Hi, the regulator is integral to the alternator on your Jag.
Part Number:
14561
Weight:
13.0 lbs
Warranty:
Limited Lifetime
Notes:
75 Amp alternatorPremium reman. Save the pulley, fan, shaftkey and/or fan spacer and mounting hardware from your failed alternator. You will need to install these parts on your replacement alternator.
Unit Manufacturer:
Lucas
Amperage:
75 A
Pulley Type:
Sold without a pulley
Fan:
External
Regulator:
Internal
Part Number:
14561
Weight:
13.0 lbs
Warranty:
Limited Lifetime
Notes:
Unit Manufacturer:
Lucas
Amperage:
75 A
Pulley Type:
Fan:
External
Regulator:
Internal
Part Number:
14561
Weight:
13.0 lbs
Warranty:
Limited Lifetime
Notes:
Unit Manufacturer:
Lucas
Amperage:
75 A
Pulley Type:
Fan:
External
Regulator:
Internal
dont know why u need to cross reference a chassis but if u need an alternator- all auto stores and dealers only need is year/ make/ model/ engine/and sometimes a vin number for any and all parts
Just get both generic part numbers from autozone or O'Reillys. If you use the Ford numbers the year number can show a different number in their part number sequence. Whether you can see the Amps rating on the alternator without removal is iffy.
