Question about Abit KV8PRO (MBABITKV8PRO) Motherboard
Abit KV8Pro Rev 1.1 BIOS 26
No Cool n Quiet under Power Management.
    Genius:
  • 1,066 Answers
Cool n quiet is a bios feature, it will be in bios, n ot windows
Posted on Jul 04, 2009
When i try to suspend my pc, my motherboard gets f3 error and then restarts. The model is an old abit ab9 pro. I recently changed the ram and my os. The os runs perfectly.
have to select suspend mode s1 or s3 in BIOS power management to check the support mode, also check with hibernate, also need to free space in hard drive system partition for hibernating
Sep 11, 2016 | Abit AB9 Pro Motherboard
How to acsess the boot device menu at post on abit il8 motherboard
.Abit did not add the BIOS post to the manual.
Watch the BIOS post, most all motherboards have the hot-key menu at BIOS post.
If for some reason the hot-key is not reported on BIOS post, then you hit the DELETE key and enter the BIOS, Advanced BIOS Features Setup Menu and set what hardware you want to boot first, under Hard Disk Boot Priority, set First Boot Device
Mar 31, 2013 | Abit IL8 Motherboard
Dont have the install disk
Hello here is the abit homepage:
http://abit.ws/page/mi/download/download_driver.php@pFUN_KEY=9000&pTITLE_IMG=_2Fdownload_2Fimages_2Fdownload.html
Try to remove the cmos battery, and insert it again.
This will reset the bios to factory defaults.
You will need to setup the whole bios, date, clock, boot settings when the job is done.
But the power supply could also be failing, or a ram module.
Good luck
Jan 01, 2013 | Abit IS7 Motherboard
Hi I am working on a abit A 17 mother board it was taken apart by my nephew. I think I have every thing back togather, but when I turn it on it beeps and shows code 92,well I think thats what the l e d box...
Hi, you can download a manual here:
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=AI7&fMTYPE=Socket 478&pPRODINFO=Manual
The fault could be the cpu, wrong type of ram, a faulty ram module
or a fault in the mainboard.
Check all the settings in the manual and the bios aswell.
Here is a list of beep codes:
Basic Beep Codes for ABIT AWARD BIOS Motherboards
  1. No beep at all - this means your motherboard is dead, either due to a defective or underpowered power supply, poorly seated CPU or RAM, or a dead-on-arrival board
  2. One beep - board is working fine
  3. One long beep then machine shuts down - faulty, improperly installed or missing CPU
  4. 1 short(Beep) System booting is normally
  5. 2 short(Beep) CMOS setting error
  6. 1 long - 1 short(Beep) DRAM ERROR
  7. 1 long - 2 short(Beep) Display card or monitor connected error
  8. 1 long - 3 short(Beep) Keyboard Error
  9. 1 long - 9 short(Beep) ROM Error
  10. Long(Beep) continuous DRAM isn't inserted correctly
  11. Short(Beep) continuous POWER supply has a problem
  12. A two-tone siren, generally caused by overheating or out of specification voltages
  13. Four beeps then machine shuts down. This is because this version of the BIOS will shut down your machine if no fan tachometer signal is detected on the fan header. Make sure you attach a fan to the FAN1 or FAN4 header or clear CMOS to reset to default (no checking).
Sep 07, 2011 | Abit AI7 Motherboard
I have bios version 1008 on the computer. Should i update the bios version to the newest one? The fans are always running, they never shut down
Actually if your MOBO are working fine as of now no need to update the BIOS version. Updating BIOS version may affect some parts of MOBO so no need to update the BIOS version.
Regards
nicole
Oct 03, 2009 | AMD Asus A8V Deluxe Socket 939 Motherboard...
Every day at 1-st turning on all BIOS are in initial def. state.
I suggest you may try to check and replace the motherboard battery prior doing other procedures.
Feb 23, 2009 | Abit NF7-S V2 Motherboard
BIOS UPDATE FAIL
Try making a disk again - use a brand new disk and check it for errors.
Feb 15, 2009 | Abit NF-M2S Motherboard
Bios update
go online and type in
bois download drivers
enter
manifacture name bois model # [date if u have one] download drivers
rod
Dec 16, 2008 | ASUS P4S800-MX Motherboard
HOW DO I SPEED UP MY FANS I HAVE A A8N-DELUX REV.1.02A MOTHERBOARD
Clean all fans of built up dust including power supply one
Clean out the Heat Sink vanes of fluff and dirt usually this is main problem
then vacuum out case including all vent holes and behind the power supply
On this site and one other doing this has got 7 computers working properly
Oct 12, 2008 | ASUS A8N-SLI Deluxe Motherboard
Abit KV8PRO (MBABITKV8PRO) Motherboard Logo
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
