Question about Amana Freezers
Amana AU150 upright freezer accumulating water/ice on the bottom
Is there a drain hole on the frost free freezer? I know something is plugged.
5 Suggested Answers
fridgetech
  • 473 Answers
SOURCE: Frigidaire Frost Free Commercial Freezer
The drain has most likely frozen over. It is at the bottom behind the back panel inside the freezer. You will need to remove all of the ice and run hot water down the drain until it is clear.
Posted on Nov 16, 2007
  • 311 Answers
SOURCE: I am accumulating ice inside my freezer
It needs to be defrosted. If ice builds up quickly again then start shopping for another freezer as the repair is not worth it. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Posted on Nov 28, 2008
  • 400 Answers
SOURCE: ICE BUILDUP ON BOTTOM OF FREEZER, DRAIN HOLE FROZEN
There is normally a small filiament of metal which is attached to the defrost element and conducts heat down the drainpipe preventing ice build up. You can pour some boiling water onto this area and even wriggle a piece of plastic tubing down the drain pipe to dislodge any blockage. For future prevention, you can attach a piece of copper wire around the defrost element (in the absence of the original filiament) and extend it down the drainpiple
Posted on Mar 05, 2009
heatman101
  • 43501 Answers
SOURCE: water is accumulating in the bottom of the freezer
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on May 27, 2010
Testimonial: "Will check out and see if it works. Next issue is how do I get to the drain line?"
Ice in the bottom of freezer
Greetings,
the drain is clogged most likely...remove lower shelves, baskets, remove rear panel if self defrosting.. find the drain hole and use a hair dryer or hot water to defrost ice..once the surface ice is off...you will need to make sure there is no ice in drain tube going down under freezer. use a squeeze bottle with hot water and force it into drain. do this repeatly until water runs free down drain....Bruce Denton
Jan 09, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Icing up
I've just had a similar problem. I fixed it by removing the large panel on the back of the inside of the freezer. I found a large build up of ice at the bottom of the freezer which seems to have developed because the drain hole at the bottom of the freezer was blocked. I defrosted the ice, cleared the drain and now the freezer is working fine.
Jul 23, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Amana Freezer DeepFreeze AFU2067BW 19.6 Cu. Ft. ice in bottom
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
heatman101
Feb 20, 2010 | Amana Freezer DeepFreeze AFU2067BW 19.6...
Water/Ice pooling in bottom of freezer
check out the drainage hole if it is properly closed.
Freezer forming Ice on the bottom not draining water
pour some hot water in the drain if this does not work use compressed air
Aug 23, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frost free freezer with ice in the bottom and water dipping off bottom door hinge
Frost Free Freezer have an automatic defrost, which is essentially a heating element which melts any ice. If your door seals are in poor condition or something is preventing the door from sealing the ambient air may be melting the ice more than the drain can accommodate. Check the drain in the bottom of the freezer. Humidity can also cause more water to accumulate, especially if the door seals are not sealing.
Jul 10, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Frost free freezer
Hi, It sounds like the defrost drain is plugged. UNPLUG the freezer. Remove the rear panel and you will be able to find the drain hole and remove the ice. Once you get the iceout of the drain. try and fluxh it with hot water (A baisting serigne works great). Sometines they plug up with duse from underneath. I hope this helps you. Please let me know if I can assist you further.
Thanks
Vic
May 16, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore upright freezer Model # C675-287140J Serial # 08462430AJ water is freezing in bottom tray and building up.
defrost drain may be plugged.shut freezer off,melt ice with blowdryer,and unplug drain.drain probably located behind inner back wall beneath coils.
Mar 08, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Drain iced up in freezer
the draining pipe is block with something, you can melt the ice with a hear drier or hot water, then put a wire true the pipe and after that, test the pipe again.
Jun 02, 2008 | Maytag 15 cu. ft. / 425 liter Upright...
Puddle
all frost free freezers have to defrost the coils. there is a drain pan or cup in the bottom .. if it overflows or it can't drain out you will get puddles check the drain hose and drain cup or pan.. also check to see if you have ice inside the bottom of you freezer that would be a plugged or freezing drain hose..call for services if only 4 months old...
Apr 20, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezers Logo
53 people viewed this question
Top Amana Freezers Experts
Victor Nwachukwu
Victor Nwachukwu
Charles T Nevin
Charles T Nevin
Sal De
Are you an Amana Freezer Expert? Answer questions, earn points and help others
