Question about Tecumseh Horizontal Tiller Engine 8 Hp, 1" X 2 57/64" Shaft, Modelno. Hm80 - 155656x
I just got my old gokart sorta running again it has an old tecumseh 5.5 ohv enduro engine in it . it had been sitting for like 3-4 years and i cleaned the coil and what not got spart again and now it will only run for about 5-10 seconds then it dies and it doesnt respond to throttle . do i need to clean the carb better . i need help LOL.
    Novelist:
  • 131 Answers
Clean the carb again and also check all the gaskets, make sure none have moved or rotted from sitting, check the butterfly in the carb also and make sure it moves and does not get binded up. spray some throttle cleaner in the carb and clean it out good using a rag, dont use a brush cause you dont want to get any more **** in the engine.
Posted on Aug 14, 2009
    Problem Solver:
  • 5 Answers
Yes, clean the carb again.
Posted on Jul 03, 2009
Toro snowthrower coil condensor points
If you have changed sparkplug and coil and cleaned flywheel, you probably have a kill wire problem. Disconnect kill wire from coil and try again.
Apr 04, 2014 | Tecumseh Enduro Horizontal Engine 5 HP...
Valve settings ohv
Check with Parts Tree Repair Clinic
May 30, 2013 | Tecumseh Enduro Vertical Engine 16 HP 1in...
My tecumseh will start but will not run when the chocke is of and will not get to full throtel
Sounds to me like you need to clean your air filter. Try the fuel filter, too, but I'll bet it's the air filter!
Feb 03, 2012 | Tecumseh Enduro Horizontal Engine 5 HP...
Have a 12 hp Tecumseh engine that bvackfires with ohv
Your problem could be one of several things.. A bad spark plug, bad gas, failure to lower the idle and let it run a few seconds prior to shutting it off, unadjusted valves, etc.
I'd start with the plug and some fresh gas, then go from there. Always idle the engine down for a few seconds before shutting it off. This allows all the gas in the combustion chamber to be burned up preventing backfire.
Jan 14, 2012 | Tecumseh Enduro Vertical Engine 16 HP 1in...
Mower starts and runs for 10 - 15 seconds, then dies. Will almost start again, but soon will not even kick over. After a while, it will start for a few seconds. This is a 15 horse Tecumseh that looks...
It sounds like a carburetor issue. The jets are probably gummed up from the old gas that was in it. Remove the carburetor and clean it out with a can of carb cleaner. Then reinstall.
May 22, 2011 | Tecumseh Enduro Vertical Engine 16 HP 1in...
Tecumseh 16 hp ohv adjustment
It is always best to have the exact model number of the engine you want to work on. Here is a helpful link:http://www.tecumsehpower.com/CustomerService/BSI.pdf
Jul 03, 2010 | Tecumseh Enduro Vertical Engine 16 HP 1in...
Tecumseh Horizontal Tiller Engine 8 Hp, 1" X 2 57/64" Shaft, Modelno. Hm80 - 155656x Logo
318 people viewed this question
Top Tecumseh Tools & Hardware - Others Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ArcFlash
Level 1 Expert
JonSnell Electronic
JonSnell Electronic
Are you a Tecumseh Tool and Hardware - Other Expert? Answer questions, earn points and help others
