Try another outlet to make sure the outlet didn't go bad on you, then if that doesn't work, go ahead and try another known good working adapter if possible.
At that point if the working adapter doesn't get the Wii to turn on then that means the main board inside the Wii is bad and if its under warranty then call Nintendo and get them to replace the Wii.
can not get the wii fit stepping board to stay on Tried syncing the board to the wii fit console by...
(More)
can not get the wii fit stepping board to stay on Tried syncing the board to the wii fit console by depressing both red buttons at the same time for a few seconds. The wii fit balance board flashed a blue light for several seconds then goes off. When I try to turn it on it flashes once then stops. Have replaced batteries all brand new still no change?????
how do I remove the case on the controller, suspect some thing has been put in slot other than a...
(More)
how do I remove the case on the controller, suspect some thing has been put in slot other than a disk
I can turn on the power with the remote or at the console, but I can not turn the power off with the...
(More)
I can turn on the power with the remote or at the console, but I can not turn the power off with the remote or at the console. I also can not get a picture, the disc loads ok, it seems the remote will not work properly. I did replace the batteries.
