SOURCE: Hi I'm looking for cylinder head torque settings for a 1992 BMW 316/318 e36
BMW cylinder torque setting all models
According to my service manual as follows.
Cyl head to engine block (torx e12 M10 bolts)
Stage 1 30nm (22 ft – lb)
Stage 2 + 90 degrees
Stage 3 + 90 degrees
Cyl head to lower timing chain cover 10nm (89in – lb)
The tightening sequence is from inside to outside crossover as normal. Loosening sequence is from outside to inside crossover. Remember to set torque wrench at low setting and work gradually up through the whole sequence until you get the desired torque.
SOURCE: 94 mazda B3000 3.0L cylinder head torque specs
Step 1 torque to 59 ft pounds
2. Loosen one full turn
3. 37 ft pounds
4. 68 ft pounds
Use torque sequence below
SOURCE: need cylinder head gasket torque specs.
looks like there is special sequence to reassemble and tightening, a quick note replace any bolts that have two punch marks.tighten as follows: x x x x x 10 4 2 6 8 x x x x x 7 5 1 3 9 torque all down to 15 ft lbs torque to 30 ft lbs plus 90 degrees. Good luck!
SOURCE: I have 4.9L6 need torque specs for cylinder head
for cylinder head the torque is : step 1 55 ft-lb, step 2 65 ft-lb, step 3 85 ft-lb. Rocker arm stud nut or bolt is 17 to 23 ft-lb. and valve cover bolt 72 to 108 in-lb.
SOURCE: golf iv 1.6 8v cylinder head torque settings
hi to tighten you have to do it in 4 stages as follows
1st stage 40nm leave 5 mins
2nd stage 60nm leave 5 mins
3rd stage 90 degrees leave 10 mins
4th stage 90 degrees
then you are done i will try put order on here i hope this works as follows
10 4 2 6 8
front of engine back of engine
7 5 1 3 9
in that order hope this helps
Since you didn't say which engine you have, I've pulled torque specs for 3 different engines. Also, since I can't include a diagram showing the relative locations of the numbered head-bolt locations, it would be a good idea for you to purchase a vehicle specific repair guide that will show this info.
Take particular note about the TTY (Torque to Yield) bolts used on 2 of the 3 engines shown. It is said that new head bolts MUST BE USED when head is replaced or re-installed to obtain the proper torque.
B2500 4 Cylinder
Torque sequence: --------- ' 10 6 2 4 8
' front ' ' ' 7 3 1 5 9 ' -----------Step 1: torque in sequence to 51
Ft/Lbs Step 2: torque again in sequence to 51 Ft/Lbs Step 3: final
tighten all bolts an additional 90 to 100 degrees recheck final
torque in sequence *** CAUTION ***engine uses Torque To Yield head
bolts (TTY) that permanently stretch during the initial installation.
New head bolts must be used when cylinder head is replaced or
re-installed to obtain proper torque.
B3000 3.0 6 Cylinder
Torque sequence ---------- ' 6 4 2 8 '
' ' ' 5 1 3 7 ' ---------- Step 1: torque to 59 Ft/Lbs Step 2: loosen
in sequence (1) full turn Step 3: torque to 41 Ft/Lbs Step 4: torque
to 73 Ft/Lbs
B4000 4.0 6 Cylinder
Torque sequence --------- ' 5 1 3 7 ' '
' ' 6 4 2 8 ' --------- Step 1: torque cylinder head bolts in
sequence to 26 Ft/Lbs Step 2: torque cylinder head bolts to 56 Ft/Lbs
Step 3: turn cylinder head bolts in sequence an additional 90-degrees
recheck final torque in sequence *** CAUTION ***engine uses Torque To
Yield head bolts (TTY) that permanently stretch during the initial
installation. New head bolts must be used when cylinder head is
replaced or re-installed to obtain proper torque.
Good luck with this job!
