Question about Ertl 580 Super M Series II Tractor
Case 580c hyd problems
Weak hyds on the hoe end of the machine excelent power on the stab jacks and the loader end the back bucket jack is very weak and the boom jacks will hardly lift , then some times the boom jacks have good power but not enough
  • 11,896 Answers
There may be air in the system. Otherwise the seals are leaking
Posted on Jul 03, 2009
Hi!, it is and old 580C Case tractor with a back hoe and bucket. I went out to start it the other day, pushed the starter and nothing, like it was completely disconnected.
Check the battery and see if it is fully charged. Check your battery cables to see if both end are tight and clean. If corroded needs to be clean and tight. Your starter could be the fault. Start with the battery and cables first then if they are ok check the starter. You can purchase a battery power tester that you can see if power is going to the starter with out tearing things apart.
Nov 08, 2016 | Garden
John deere 332e skid steer loader
I would change hyd. fllter. Clean the hyd. screen
Jun 23, 2016 | John Deere Garden
How can i fix a floor jack it does not go up
that depends did it leak oil out of the shaft seal ? if it did you could add more oil to resavor but that would not be safe as oil will continue to leak out seal and jack will fall down , Most auto parts stores sell hyd jack oil in a can
Sep 22, 2014 | Cars & Trucks
Hyd problem with JD tractor
Crack your hoses on cylinders to get air out of them.
Feb 06, 2014 | Garden
My 2 stage floor jack raises to load point, butbut no further -- at this point you cannot pump the handle
raise the head all the way up remove plug and fill with hyd fluid replace plug and try to jack it should go all the way up...i had same problem..
Feb 27, 2012 | Cars & Trucks
Ford TRactor 1710 hydraulic problem
raise front loader....loosen hyd. line a little lower loader till all air is released and only fluid is coming out and retighten.....its like bleedig brakes on a car
Nov 16, 2009 | Plumbing
631 clark skid steer won't drive or steer the left side? the chain is still on the sprockets.
With all the hyd pressure released, need to unhook the 2 big hoses going to the hyd motor on the chain case on the left side and CAP OFF with fittings. Next start the machine and SLOWLEY move the travel control for the left side a little front and back, you should hear a loud growl from the hydrostat, showing that it is pumping under load. Dont do this long, but enough to test. No noise means the problem is in the hydrostat, possiably bad slipper plate, rotating group or both high pressure relief valves.If you have noise the problem is in the hyd motor. Good luck and be carefull!!!
May 09, 2009 | Bruder Cat Skid Steer Loader
Ertl 580 Super M Series II Tractor Logo
955 people viewed this question
Top Ertl Toys Experts
Colin Stickland
Colin Stickland
Ron Knox
Ron Knox
Level 1 Expert
Are you an Ertl Toy Expert? Answer questions, earn points and help others
