Question about Whirlpool GS460 Gas Kitchen Range
The oven setting was accidently changed to celcius. How do you get it set back to fahrenheit
  • 999 Answers
Press and hold Custom Broil till it beeps then press off/cancel to exit.
Eric
Posted on Jul 04, 2009
How do I switch my Panasonic NN-CD989S from Celcius to Fahrenheit?
talk with your local service agent and see if he can advise on what to do as he probably has met this problem in servicing units and has to change the setting
Jul 07, 2016 | Panasonic NN-CD989S 1.5 CU FT GENIUS...
HOW TO REPAIR A THERMOSTAT
Hi, it won't cause your oven overheating by hanging loose. I think your thermostat is faulty. I don't suggest opening it to try and repair it yourself. If your tamper with the metal plates inside, your temperature will not be accurate as where you set it for 120 degrees Celcius or 248 fahrenheit it will meybe give you a true temperature of 220 degrees celcius or 428 fahrenheit which would be chaos. Rather rplace the complete thermostat unit.
May 03, 2014 | Bosch Ovens
How do you change the key pad from celcius to ferenhite on my whirlpool acubake oven
Look for the button marked "Precise Clean" in the upper left corner of the control panel.
Press and hold this button for five seconds until the display reads "Temperature Unit Celsius.
Release the button and push it again for another five seconds until the display shows "Temperature Unit Fahrenheit."
Push the "Off/Cancel" button to lock in the Fahrenheit setting.
Jul 10, 2011 | Whirlpool SB160PEE Gas Single Oven
MY OVEN IS VIKING OVEN CAN YOU PLEASE TELL ME HOW TO CHANGE FARENHEIT FROM CELCIUS
Hi and welcome to FixYa, I am Kelly.
Here is how you change it:
Degree Format
The oven has been preset to the Fahrenheit temperature scale.
With this feature, users can switch to the Celsius temperature
scale.
To change degree format to Celsius:
1. Press "SETTINGS." Settings menu will appear in display.
2. Press the up or down arrows until "DEGREES:
FAHRENHEIT" appears in the display.
3. Press "ENTER" to change degree format. Current value
will flash.
4. Use arrow keys to select "CELSIUS."
5. Press "ENTER" again to set degree format.
6. To exit the Settings menu, press "SETTINGS."
You will need to press the up or down button after pressing settings until you see Celsius appear then press ENTER and the Celsius flashes then use the arrow key to select Fahrenheit (still flashing) and once again press enter (saves) and it stops flashing. then press settings to exit the settings menu.
Thanks for choosing FixYa,
Kelly
Mar 22, 2011 | Microwave Ovens
I have a honeywell thermostat magic stat/32 model 3200. It reads celis and not farinheit. Just started doing this.
Remove main stat from subbase. On back of main stat there are some screws used for different settings. Screw "C" if for fahrenheit and celcius. Screw in for fahrenheit and out 1 turn for celcius.
Jan 17, 2011 | Honeywell Heating & Cooling
Getting oven back on fahrenheit instead of celsius
Actually for the Whirlpool Accubake I just figured out, the bake button didn't work, but holding the broil button did the trick.
Apr 19, 2009 | Ovens
I cant figure out how to change my thermometer back from celcius to fahrenheit
Make sure that the odometer is set to miles and not kilometers. Hold the button down (while in the regular odometer setting, not the "trip odometer" setting) until it changes to miles. The temperature display will automatically change to fahrenheit. We just figured this out today.
Aug 23, 2008 | 2006 Ford Freestar
Whirlpool GS460 Gas Kitchen Range Logo
110 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
