Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Door hit bottom and goes back up. one sensor light is green and
One sensor light is green and the other is green. itryed to allign and removed all obstructions and cleaned the sensors. what next???
    Sergeant:
  • 353 Answers
Your door must have a pressure switch, and it is hitting the floor before the motor stops.
with the door topped out, release the lock and push the door closer to the motor and relock.
have a helper present to be safe
Posted on Jul 03, 2009
    President:
  • 3,197 Answers
If your door reverses when it hits the floor and the main light does not flash 10 times then the door is just closing too far. On the side of the motor unit you will find the 'down limit' control. Turn this a bit in the opposite direction of the arrow printed on the cover. It may take some adjusting to get it just right.
Posted on Jul 04, 2009
There is a lose wire on my garage door opener. You can see that it is not in place. The garage door works from the door button, though it has to be held down but not from the remote.
If the loose wire is coming from the motor area, it may be the sensor wire that receives the signal from the remote. If it's at the bottom of the garage door near the sensors it may have come off from the sensor. Holding the button to make it go down is a symptom of one of the safety sensors not working. Make sure the lights are green.
Oct 29, 2017 | Cars & Trucks
I have an access master door opener..it goes up about 6 inches and stops, hit switch again, goes down, hit switch again goes up about two feet, hit switch again goes down, third time switch nothing until...
Door sensors have nothing to do with door opening. Only closing. It sounds like you have a bad gear in the motor unit. Remove the cover and it will be obvious if the gear is bad.
Feb 15, 2011 | Sears Craftsman LiftMaster Chamberlain...
We have a 1/2 hp garage door opener and it is blinking 4 times. it will shut with continuous pressure on the button but not with a single press. the sensors are different, one has a continuous yellow light...
The most common reason for the green sensor to flash is because they are not pointed directly at one another.
  1. Check each sensor for a steady glowing indicator light. If both indicator lights are on, or if one indicator light is flickering, the sensors may be slightly misaligned. To check for misalignment; obstruct the beam of the sensors so that they cannot see each other. When the beam is blocked, the indicator light on one of the two sensors will temporarily go out. This is the receiving sensor. Remove the obstruction and loosen the wing nut on the back of the receiving sensor. Adjust the receiving sensor until the green indicator light goes out, if not already out, then realign until the green light is bright and steady, then retighten the wing nut. This usually takes a couple of attempts before it is back in alignment.
Jan 01, 2010 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster formula 1 garage door opener keeps "bouncing" open
If the door reverses when it hits the floor it is traveling too far. Locate the 'down limit' control on the side of the motor unit and turn this in the opposite direction of the arrow printed on the cover. Some tweaking will most likely be necessary. You can always recognize a sensor problem because the main light will flash 10 times. If the main light isn't flashing it isn't a sensor problem.
Sep 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door will not go down
The only thing that will cause the main light to flash 10 times and the door to reverse to the open position is a door sensor problem. Check to make sure one of the sensors is not blinking ever so slightly. It can be hard to see. Also make sure direct sunlight is not hitting the lens. Try shading them.
Jul 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Doors open but will not close
Check the laser. Make sure that the safety lasers are properly alligned, If the bottom sensors next to the floor on the door rails sounds like it has been moved and just needs to be realigned. Pretty simple work to take care of the problem unless the sensor is broken
Apr 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener will not go down.
After reading the responses I went out and looked at the sensors, but this time instead of aligning up and down I moved the one sideways and WOOHOO! the remote works fine now.
SherAng
Apr 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door sensors are alligned, we cleaned the lenses
i m trying to change code i m new other ppl didnt give me the password how to change it my own??
Feb 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door ups and downs
Holding the button down just bypasses the sensors.
Your sensors are not adjusting correctly, or there is a short in the wires.
The back of the machine has a little yellow light, count the flashes and corelate it to the troubleshooting portion of the manual to confirm.
The orange light is a constant, the green sensor needs to be adjusted until you get a solid green light.
Apr 30, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Garage door opener doesnt close the garage
If you have to hold down the button to close the door, you are bypassing the sensors ...
Check the alignment of the sensors. Should see a solid GREEN light
Nov 28, 2007 | Chamberlain Powerdrive PD422D 1/2 HP...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
146 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
