The Lamp is designed to be replaced by the customer. The Lamp Door is on the right side of the set as you look at it from the front. You Must first remove the cover, then turn the handle of the Lamp Door counter clock wise. Pull the Door out. The Lamp is now exposed. Lift up on the finger loop of the Lamp and pull.
Replace in reverse proceedure. The Lamp can be ordered by calling Sony at
1800-222-SONY.
Hope this Helps,
Skyassoc
ok so this started about 6 months back, then it would just shut of for 5 min then have no problems...
(More)
ok so this started about 6 months back, then it would just shut of for 5 min then have no problems for a long time when i run diagontics no errors and it appers it is just the screen and audio b/c when in menus and such if the screen shuts off then menu is right were it was when it comes back on
Sony KDF-E55A20 tv starts normally, but he screen goes black and sound cut out after 2 or 3 minutes....
(More)
Sony KDF-E55A20 tv starts normally, but he screen goes black and sound cut out after 2 or 3 minutes. The picture and sound then returns after 20 or 25 seconds, but 3 minutes later the whole process repeats.
Greetings, I have a 55 inch sony LCD TV. Today, when I turn it on, the green powe light keeps...
(More)
Greetings, I have a 55 inch sony LCD TV. Today, when I turn it on, the green powe light keeps blinking for 2 minutes. Then, a series of vertical lines appear which are of various different colors. No sound either. What is happening? Thanks
