Question about Dell W4201C 42 in. Plasma HDTV
Dell W4201C half black screen
I have been researching this problem online and it seems to be common. Basically, the bottom half of my plasma is black. I still have audio. Is this something a novice can fix? I read some other solutions about power/voltage to the screen... possibly a loose or defective wire. It sounds like Dell repair/support is a nightmare.
    President:
  • 1,077 Answers
It should be easy enough for a Novice to fix.
Most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, if you can find and purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jul 04, 2009
W4201C no picture only sound
Try to use dvd player to play video to determine where the problems goes wrong either from the video signal of the cable provider or from the TV itself.
Please let me know any update.
Nov 23, 2007 | Dell W4201C 42 in. Plasma HDTV
Black line in the middle of screen
It is possible the connector to from the address board to the screen may be need to be cleaned & re-seated, but almost 99% of the time this fault is a problem within the plasma screen & the only solution is for a replacement screen.
Aug 14, 2009 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
SOUND AND NO PICTURE ON DELL PLASMA W4201
Y SUS and Buffers are usual culprit.
You can get it from guy at
plasmatech@gmail.com
He has everything for Dell TVs
Jul 29, 2009 | Dell W4201C 42 in. Plasma HDTV
My 42" plasma tv screen went black but there is still audo
The most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
Jun 27, 2009 | Dell W4201C 42 in. Plasma HDTV
Dell W4201C - Screen goes black then comes back on
you need to check to see if screen goes black on all inputs. you might have bad digital module. you can get modules at discountmerchants.com J.D.W.
Jun 15, 2009 | Dell W4200 42 in. HD-Ready Plasma...
No picture or sound on Dell w4201c plasma tv
hi its right time for u to go for a replacement of new plasma screen... its available in dell shops... bcoz repairing might cost u heavier...
thank u rate me
Feb 09, 2009 | Dell W4201C 42 in. Plasma HDTV
Dell 42 inch plasma has no image or sound
needs new panel and a updated power board. firmware must be 51-7 (current)
Jan 21, 2009 | Dell W4201C 42 in. Plasma HDTV
Black vertical lines is there a fix My problem is with a hoizontal thin black line on my Dell 42" Plasma TV. Any suggestions for a fix? I had tried turning off and disconnecting from cable for awhile,...
I have the same problem. My repair shop says I need a new plasma screen. Dell says replacement screens are unavailable. I now have a 42" paperweight.
Jul 22, 2008 | Dell W4201C 42 in. Plasma HDTV
Dell w4201c hdtv plasma tv BLACK SCREEN, LOGO FADES OUT, SOUND REMIANS, HELPPPPPPP
the problem was the y-sus board, i had a local tv repair shop diagnos that much for me. although, he couldn't fix it i did some research and found a company in california, itritek.com, who could. you send him the y-sus board and the two buffer boards and he not only repairs them but he upgrades them. apparently the y-sus board gets too much heat and eventually goes out, sometimes the buffer boards are affected too. itritek.com replaces the components on the y-sus board with better parts which are more heat resistent. i believe this will help you with your problem. let me know...good luck.
Jul 12, 2008 | Dell W4201C 42 in. Plasma HDTV
Dell W4201C 42 in. Plasma HDTV Logo
460 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
