I had drop my phone in a bowel of salsa and i wanted to open my phone up and see if its still wet and i had un screwed all the scews and i cant take it a part what else do i nee to do to take it a part
Although it is not necessary to open and you may only have to wipe the phone down. If for any reason you need to open it to change the cover do the following. For the battery faceplate remove the screws then use either a small eyeglass flathead screw driver or a ipod tool to pry the csae open on the sides then on eah end. For the top do the same on both side then at the botton lip. The top where the camera lens is should slide off, you will then have to carefully lift the tape then gently lift and pull the cable, it is only glued down. then replace it aligning the white lines together.
You probably shouldn't take your phone completely apart. Just take the battery off and wipe the salsa off. The same thing happened to my phone, except with Dr. Pepper, and that's what did and after a few days of being sticky, it worked fine.
