Question about HP JBL Platinum Computer Speakers
The sound on my speakers sounds distant, almost like an echo.
    Problem Solver:
  • 4 Answers
Do you have a sound card? If so are you plugged into the green plug on the sound card and not the green plug on the intregrated board on the computer. Have you updated the driver lately? If not you can try that. Open your control panel and go to sound and audio devices, go to speaker setting advanced and select the speaker combination you have to assure that is correct. You can also see your video card here if you have one. Now this is on XP format. There are other setting you can view and change there also.
Posted on Jul 04, 2009
My new Vizion tv has a vizion sound bar, the sound comes out with an echo, how do I correct?
Your TV speakers should be turned all the way down or off when you use a separate sound system such as a soundbar. Using them with the soundbar may cause echoes and the TV speakers do nothing to improve the sound.
Look at your TV's audio menu. If you can, turn the TV speakers off completely at the menu. Also see if you can set the analog audio output to "variable." This will allow you to control the soundbar's volume with the TV remote.
Jul 08, 2017 | Echo Computers & Internet
Echo through speakers
Unintended reverberation, or "echoing," from your computer speakers is a common problem that can arise from improper setup of your audio properties.
Resetting all of your audio information to default will correct this problem, allowing you another chance to strike a good balance to satisfy your audio tastes.
This can be accomplished by accessing the Sounds menu in your operating system.
Select the "Start" menu from the bottom-left corner of your screen, and click on "Control Panel." Find the "hardware and Sound" button and click to select.
Click on the sound icon and select the third tab labeled "Sounds" in the window that appears. A list of sounds will appear, beginning with "Asterisk." Click on a sound to highlight and select test.
Listen to hear if the echoing problem occurs.
If it does, you need to configure your speakers or check to see if it is a third-party issue.
Select the first tab labeled "Playback" from the same window. Right-click on the "Speakers" icon. Click on "Configure Speakers" from the top of the list.
Choose a setup from the list that appears and select test to test different sound configurations for the speakers.
Listen to decipher if one configuration has less echo than another. If so, choose the speaker configuration without the echo to fix the problem.
However, if none of the configurations remove the echo, you need to attempt to troubleshoot the issue from "Safe Mode."
Turn on your computer if it is off or restart your computer. Continuously press the "F8" key until the "Advance Boot Options" screen appears.
Use your arrow keys to navigate the screen, pressing down until you have highlighted the "Safe Mode" option. Hit "Enter" to select. Wait for the drivers to load.
Log on from the "Administrator" account. Test the sounds again, and if the echo does not occur, the cause is a third-party driver or service.
hope this helps
Sep 15, 2012 | ASUS Computers & Internet
So when I listen with my headphones now, they only play the background music (if that makes sense). The music is almost echo-y and sounds far away. I rarely get the main music/singer, and if I do hear...
leezamastre,
It sounds like this might be a setting on whichever MP3 player, or sound device that you are using. You should check for an "EQ" on your device and try setting it to a different setting to make it so you can hear the music and vocals of a song.
Please let me know if you have any other questions about this,
Cheers,
Garbanian
Aug 08, 2011 | Skull Candy Audio Players & Recorders
Sounds sound like an echo chamber
1. Click Start, click Control Panel, click Hardware and Sound, and then click Sound.
2. In the Sound window right-click your Speakers and select Configure Speakers.
3. Follow the on-screen setup, and Test the available configurations.
4. Indentify whether or not one configuration appears to have less of an “echo” than others.
5. If the issue is resolved by modifying the configuration then you do not need to do anything further
May 18, 2010 | E-Machines eMachines Desktop PC
Speakers seem fine except they seem to have an echo to them
the echo is a software effect on your computer check the sound card and driver under control pannel under sound make sure reverb or echo is off it sucks
Dec 27, 2009 | Logitech X-240 Computer Speakers
How do get rid of echo on sound from speakers?
When you say echo, are you meaning sound coming from your mic echoing thru the speakers or a sound like your in a bathroom on all audio.
If you are referring to the mic issue, then open your volume control and make sure that MIC is muted in playback setttings
If you are refering to bathroom sound on everything , it is called a "environmental setting" and in in your sound cards software setup, like their version of the volume control or some other application they have installed for you to configure your card. Just locate the "environmental" setting and disable it / set it to none.
Sep 25, 2009 | Computers & Internet
System echos when dvd is in. When I mute the Bose sytem I can hear the TV sound without the echo.
The echo you hear is the audio delay between your TV speakers and Bose speakers. Muting (or lowering the volume) on the TV will eliminate the echo. Some TVs have a setting to turn of TV speakers entirely, allowing you to listen to your TVs audio strictly through your Bose system.
Dec 20, 2008 | Bose 3·2·1 II System
All sounds on my computer sound like they're in an echo chamber
I had this problem. I right clicked on the speaker icon at the bottom right hand corner of the screen, selected playback devices, left clicked to highlight the 'speakers' (realtek in my case) then clicked properties in the lower right of the open window, clicked on the enhancements tab, and found that my sound effect properties had been changed to auditorium. I clicked the selection arrow and changed the enhancements to 'none'. Oh happy day! No more echo.
Dec 14, 2008 | JBL CREATURE II Computer Speakers
I pluged in my speakers but the sounds are very low and wierd
you cant get echo on a specker there not made for that just normal sound
Nov 16, 2008 | Ozaki DT-500 3-Piece Speaker System...
Acer aspire 5633wlmi
How long has this been going on? Have you tried updating the soundcard drivers or rolling back to the last set of drivers if this is a recent problem?
Dec 30, 2007 | Acer Aspire 3680 Laptop
HP JBL Platinum Computer Speakers Logo
1,543 people viewed this question
Top HP Audio Players & Recorders Experts
Lawrence Oravetz
rfredey
Are you a HP Audio Player and Recorder Expert? Answer questions, earn points and help others
