Question about RCA Televison & Video
Hd52w59, curve at bottom and top, shadow doubles, colors are messed up
  • coloradostev Jul 06, 2009
    Is it very dangerous or hard to replace the IC's? Where could I buy the replacements? A local shop said they would come to my house and repair it for around $300. Would I save significant money by repairing it myself?
    President:
  • 788 Answers
Your symptom sounds like a damaged convergence IC.
There are two and sometimes three very large IC’s that control the convergence in a big screen set. They are secured to a very large aluminum heat sink.
If your colors line up in the middle of the set and at the top but the picture is concave then you may have a faulty component in the pincushion circuit. If the top and bottom are the only things that are wrong then it may be just be the top and bottom pin cushion circuit.
You may want to consult a Television Repair Technician, or repair this yourself. If you want to tackle this yourself, let me know, I can give you some direction for the repair
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Posted on Jul 03, 2009
How to fix the color alinements
You need to replace the two STK-392-560 CHIPS THIS SET USES AND DO NOT RUN THE SET WITH CONVERGENCE BOWED or soon you will have other parts bad.
May 27, 2012 | Sony KP-57HW40 57" Rear Projection...
I have a Phillips 60" rear projection TV. recently
Tv have a problems known as a convergence problems,it is dead.The tv convergence board it is dead,that why ur tv picture are R,G,B colors lines mis alignments,have colors shadows picture or 3D picture lood alike?The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 01, 2011 | Philips Televison & Video
SONY PROJECTION TV MODEL # KP-51WS510.
If the entire screen is curved, and it is not taking the whole screen, then you have a vertical deflection problem.
If the colors are double and do not match, with lines of different colors around pictures , then you have a convergence problem, often caused by a faulty convergence board.
The curving effect can be a side effect of bad convergence, or you may have both problems at once.
Unless you are a TV repairer yourself, better calling technical support. Usually you can ring the number listed on the owner manual.
Jul 21, 2009 | RCA P52920BL 52" Rear Projection...
Multi-color double images or shadows and curved screen
Alrighty, very common problem on this set. Here's a rundown of the repair if you're a DYI:
With the back cover off you'll notice a set of boards on the bottom of the TV and a pair of boards sitting up over the two bottom boards. The problem lies in the upper-right hand board which is the color convergence power supply. Either replace or repair this board. The repair involves the main power mosfet (a three legged regulator on a heat sink) and two diodes next to it.
Next, the bottom right hand board needs to be removed and a fuse replaced next to the flyback. If you are versed in electronics I can detail the repair further otherwise you're going to have to have a shop do the repair.
May 18, 2009 | RCA HD52W58 52" TV
Picture is multi color, double shadows, curved
This is failure of convergence out ICs in TV. Qualified TV tech will replace convergence out ICs or board.
Feb 14, 2009 | Philips Televison & Video
Top and bottom of picture is bowed.Images are doubled and letters
one more question , could or can you access the convergence menu ?
the fuse will be next to the flyback transformer ( high voltage ) and ill look tan in color( 3 of them )
also the flyback pins have to be resoldered also
Feb 03, 2009 | RCA HD52W59 HDTV Projection Television
Convergence. shadowing, arch top and bottom, red and green colors
You have a convergence problem. i see these set all the time at shop. first consult the article in tips and tricks section the fl231 fuse problem. it might provide some answer and might turn out to be a simple repair. If you do not have the convergence option under setup in customer menu then i say you have that problem.. otherwise it sounds like a convergence power board issue. if you have the options try autocovergence first and then if that fails try manual convergence of red and blue if the dont move then it will be convergence power board. let me know and ill try to talk you through it
Oct 06, 2008 | RCA HD52W59 HDTV Projection Television
Distorted picture on RCA LCD TV
your set has convergence problems i dont have the answer yet ,i do know that convergence broad is not what is causing this! I have one in my shop now with same problem as soon as i find out problem i will post it !!!!!
Jan 09, 2008 | RCA HD52W59 HDTV Projection Television
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Televison & Video Logo
115 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
