Question about Sony Audio Players & Recorders
I have an TA-AV431 sony surround sound reciever, the rear speakers will not work.
SOURCE: hooking up surround sound
do you need a reciever to get ceiling mounted speakers to work surround sound
Posted on Jul 13, 2008
SOURCE: samsung ht-z310 home cinema no sound rear speakers
I seen the same thing when I first opened mine except my "center" speaker wan't working. It had to do with the "Mode" it was in. The Mode button at the botoom of the remote changes the speaker configuration.
There is also an option in the setup that allows you to turn on/off speakers for the system, all of mine were either Present or Small which enables them to work.
Posted on Aug 11, 2008
  • 4 Answers
SOURCE: sony compact AV SYSTEM DAV-S400
Hi Joey - I had exactly the same problem.
In my case, I followed the advice of others and took the thing apart. On the main amp board there is a large brown capacitor. Mine had come completely loose, so I soldered it back in place with a good amount of solder to make sure the contacts were ok. I also dabbed some solder on the headphone connectors on the same board (just follow the wire from the headphone socket to the board). Well, when I put it back together and tried it again everything worked perfectly, and it has so far remained free from the error. Hope that helps !
Posted on Nov 27, 2008
SOURCE: no sound from back surround speakers
I resolved the problem by going in the dec mode (page 49 of manuel) and changing the setting to Pro Logic. That did the trick. Good Luck all.
Posted on Jan 26, 2009
spqr163
  • 37 Answers
SOURCE: Sony center speaker and rear speakers don't work all the time
try using another speaker for the center channel and the left speaker, also watch your ohm load, most of the want a 4 ohm load. try to narrow it down to see if it is the speaker or the amp.
Posted on Mar 13, 2009
Sony ta av431 Stereo Amp Front speaker do not
Have you check your sound configuration at front panel?
Oct 09, 2013 | Audio Players & Recorders
Two of my speakers are not working -no sound
If they are the rear surround speakers, they will not produce sound at all times, check this with a surround sound movie that will engage the speakers. Check the settings on the reciever to be sure you are in the correct surround sound mode, and check the movie menu to be sure you are playing in correct format. Also check that wires are correctly installed, observing polarity, under terminals at both the speakers and at the reciever. I hope this is useful, but not being onsite these are just a few troubleshooting tips to narrow the problem.
Feb 07, 2013 | Audio Players & Recorders
Only two speakers will work on my dell dimensions 2400. Trying to use the Kinyo ta-927 surround speakers
HAVE YOU GONE TO THE CONTROL PANEL AND SET IT UP IN SOUNDS AND AUDIO THEN GO TO SPEAKERS ON THE SOUND TAB AND GO TO ADVANCED AND MAKE SURE IT'S SET UP FOR SURROUND SOUND .....OK
Jul 09, 2009 | Kinyo TA-927 Computer Speakers
Reciever only allows 2 channels(speakers) at a time.
If the amplifier is not receiving a surround sound signal, you will get nothing from the rear speakers and probably nothing from the front centre. Play a dvd in dolby surround and it will work.
Apr 14, 2017 | Pioneer VSX-918V Receiver
Can n ot get rear surrround speakers to work
On this reciever you have rear surround and rear back spkrs, if your using the surr back they have to be assigned if unassigned in the settings. If using rear surr spkrs change your surr field to 5ch stereo and your rear speakers will work.
There is no 7.5 unless you have 5 subs the 7 is the total number of speakers and the .1 is the number of subs in the system
Feb 02, 2009 | Denon AVR-1708 Receiver
Just hooked up Coax cable; now talking is barely audible
is the center speaker turned up in the reciever speaker settings? each speaker can be adjusted to a level that is higher or lower or all the same as the rest. also is the dolby digital turned on in the reciever settings? and changing the surround sound pre set sounds can also improve the type of audio you are listening to in 6.1 surround sound
Dec 31, 2008 | Sony STR-DE597 Receiver
Can't get surround sound when watching tv
your RCA on your tv is acting like its in mono..it may be a problem with the jacks.  alternatively..you can buy a splitter and split teh side that sounds stronger (L) or (R) with a male to 2 female spliter out of the tv then back into l/r input on your reciever... It wont give you surround stereo...but it will soudn a whole lot better.
Nov 08, 2008 | Sony STR-DG800 Receiver
Hooking up surround sound
Jul 11, 2008 | Audio Players & Recorders
Yamaha reciever rx-v363
Thats because if you look in the owner's manual, it declares the fact that it will only broadcast sound from hdmi to monitor not speakers. For sound out of speakers need to connect additional audio cable.
Apr 21, 2008 | Yamaha RXV-350 Receiver
Cant get rear speakers to Work AVR 745 7.2 Surround!!!
Another way to solve this rear speakers problems is to go to the equalizer and have the system recognizes the sound coming out of all speakers. The AVR 745 comes with a microphone on the stick, using that to run the manual equalizer. It is the manual equalizer will set the rear speakers.
Dec 29, 2007 | Harman Multimedia AVR 745 Receiver
294 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
