No picture but when turning off, I get blue flashes.It was working fine previously.
SOURCE: Olevia LT27HVX 27 just blue screen
I just had this same problem over the weekend. Is your TV hooked up via HDMI?? Mine was and i've been having problems with the tv image shrinking whenever i turn on the tv, so i would have to change the channel 1 or 2 times for the image to come up normally. On Saturday I went to change the channel and then all of a sudden I hearld this loud pop and when the image came on it was just a sky blue screen, I couldnt see anything, but I could hear the channel. So I disconnected the HDMI and hooked up the tv with component cables I had and now it works fine. I ordered a new HDMI cable just to see if it will work again. If not, i'm calling Olevia.
SOURCE: Need a tv code
I just purchased the same model remote and the code i found for a olevia is 1207. Please try this and see if it works for you.
SOURCE: Syntax Olevia 30" LCD - blue screen, then black screen, sound is on
you have a broken inverter board. I have a LT30HV, and it had the same problem. The inverter board supplies power to the backlight. Swap it out with a good one, and you're back in business.
To test, take a bright flashlight and point it at the screen just an inch or so off the surface. If you can see your picture, then you have a blown inverter.
it may not be worth fixing it. Wait for a good sale on a new one. My inverter cost about 150, and it was a remanufactured part. Not as good as the original part as it flickers just a tad. I had to take the entire TV apart, with pieces literally everywhere. My cats loved it.
SOURCE: My olevia 237-t12 won't turn
It may abe in the safety shutdown mode due to short circuits in the power supply or in the backlight inverter board.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
