Question about Air Tools & Compressors
Compressor won't start-up unless check valve is held open. Once it starts it will build pressure as normal and cutoff at correct pressure but will not restart until all pressure is bled off. Process has to start al over again.
  • 6,927 Answers
Replce that valve it is a head presure release type valve the compressor will not be able to push against that much presure to start
Posted on Jul 03, 2009
Cl6506016
Hi Larry
Here are a few things to check, you may have already checked some of these.
Electricity...Compressors will run best with full 115Vot 15AMP/Or 220V electrical supply from a circuit, over the shortest electrical cord as possible.
Air Leaks..Place your ear close to the compressor and listen for air leaking, if you hear air that is not normal and means you have to locate and repair whatever it is that is leaking.
Check the air unloader valve... The air unloader valve will blown out air when you turned off the compressor, that is normal.
But it should not have air leaking out of it all of the time. If so then it is faulty and in need of repair/replacement.
Valves...If either the intake or exaust valves fail, breaks, or fails to seat, then your compressor will run 24 hours a day and never build up to the correct pressure for shut-off.
Gaskets...Check to see if your gaskets have failed.
You could have a gasket failure between the pistons and you will never know it because it shows no external air leak.
If this situation happens then the air will only cycle between cylinders and never build up the correct air pressure.
One way to check the gasket is remove the air filter, then put your hand over the intake.
Please take time to rate me
Bud
If correct then it will suck you hand against the intake.
If the valve or valves have failed then you will feel the air sucking in and blowing out.
Piston Rings and Cylinder...The piston rings could be stuck,broken, or worn and not allowing the correct pressure to build up in your tank.
A worn cylinder will also contribute to the problem of pressure build-up.
Pressure Switch...Check for air leaks at the pressure switch, it has a rubber diaphram that can fail and leak air out of the system.
Bud
Apr 30, 2013 | Air Tools & Compressors
My ingersoll rand compressor won't get up to set pressure
Hi bryon
Bud
Bud
Apr 05, 2013 | Air Tools & Compressors
I have a porter cable compressor, but the pump won't shut off, and the pressure won't build it
Hi
*Electricity...Compressors will run best with full 115Vot 15AMP/Or 220V electrical supply from a circuit, over the shortest electrical cord as possible.
*Air Leaks..Place your ear close to the compressor and listen for air leaking, if you hear air that is not normal and means you have to locate and repair whatever it is that is leaking.
*Check the air unloader valve... The air unloader valve will blown out air when you turned off the compressor, that is normal.
*Valves...If either the intake or exaust valves fail, breaks, or fails to seat, then your compressor will run 24 hours a day and never build up to the correct pressure for shut-off.
*Gaskets...Check to see if your gaskets have failed.
If correct then it will **** you hand against the intake.
*Piston Rings and Cylinder...The piston rings could be stuck,broken, or worn and not allowing the correct pressure to build up in your tank.
*Pressure Switch...Check for air leaks at the pressure switch, it has a rubber diaphram that can fail and leak air out of the system.
Bud
Nov 01, 2012 | Porter Cable Air Tools & Compressors
Takes long time to pump up, then have to shut it down, compressor acts like it wants to stop, but if I remove small line and let the air out of that side where the line connects, it will run fine but of...
Hi dmream55...
Sep 22, 2011 | Campbell Hausfeld 5HP 20 Gallon Single...
The compressor only builds up pressure to 45 psi and constantly runs. The problem started after it was left on for 2 days straight.
Hi thadlewis....
Sep 21, 2011 | Porter Cable C2002-WKR 150 PSI, 6 Gal....
My coleman air compressor won't turn on and I am trying to ghet the top off to see what the problem is. A) How do I get the top off? and B) Why doesn't it turn on?
Hi
Sound like your pressure switch is faulty or maybe a faulty motor but:
Aug 28, 2011 | Coleman CL0551509H 15 Gallon Portable...
Craftman air compressor #919.166441 won't go above 50lbs. No leaks can be found. Holds air for days. Bought new regulator, same problem still exists
Hi
Here are a few things to check.
You may have already checked some of these.
Aug 25, 2011 | Craftsman Air Tools & Compressors
Hot air comes out at all times even when i turn on a/c
I think your cooling fan (elecric) isn't working when the a/c is on. If so, The a/c pressure climbs very high and pops open the emergency pressure release to save the system from damage.
Check your cooling fan and relays, or ect, engine collant temp sensor.
You may have to add freon too.
A/C Pressure Cutoff Switch
The A/C pressure cutoff switch is used to interrupt A/C compressor operation in the event of high system discharge pressures.
  • The A/C pressure cutoff switch is mounted on a Schrader valve-type fitting on the A/C compressor to condenser discharge line.
  • It is not necessary to discharge the refrigerant system to remove the A/C pressure cutoff switch.
  • A valve depressor, located inside the threaded end of the A/C pressure cutoff switch, presses on the Schrader valve stem.
  • This allows the A/C pressure cutoff switch to monitor the compressor discharge pressure.
  • When the compressor discharge pressure rises, the switch contacts open, disengaging the A/C compressor. When the pressure drops, the contacts close to allow operation of the A/C compressor. For specifications regarding operating pressure(s), refer to Section 412-00 .
The switch contains a second set of electrical contacts used for high-speed cooling fan control.
  • When the compressor discharge pressure rises, the contacts close and engage the high-speed fan control. When the pressure drops, the contacts open and the high speed fan control is disengaged. For additional information, refer to Section 303-03 .
Apr 24, 2009 | 2001 Mercury Grand Marquis
WILL NOT BUILD PRESSURE
Many craftsman compressor are built by champbell hausfeld using a dry type of cylinder and piston (no oil, no crankcase). If dry type, check for worn cylinder and piston ring. Pieces of the vinyl ring can jamb between the reed valves in the head causing air to escape from the intake. If your compressor has a crankcase and oil, check for broken reed valves in head. Spray soap solution on hoses, checkvalve, drainvalve, and fittings to check for leaks. Most likely problem is reed valves broken or open. Parts are available from sears or match parts to chpower.com. enjoy
Nov 26, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
