Question about Jandy Lite2 Lj175n 175,000 Btu Natural Gas Heater
My header goes on, then after awhile, it shuts off
Then the code says flo, so what is the problem and how do I fix it and where do I get the parts.
    Champion:
  • 246 Answers
Clean the filter first
Posted on Oct 15, 2009
What can go wrong when changing the headers?
Some codes are hard to kill even after their cause is fixed.
Erase the codes with ignition on and the engine off. May not solve your problem but it's worth a try. Next Scan for codes. If you don't have a scanner most auto parts stores will do a free scan (Auto Zone ,Advance auto parts and others)
Apr 19, 2013 | 2003 Mitsubishi Eclipse - GS, 2.4L 4-cyl....
Which wire goes to h, which wire goes to c, which wire goes to l?
The black wire goes to H (high) White wire should go to C and green to the I.
Rod
US Parts Center
Jan 14, 2013 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Fl0 and fl3 service lights come on have flow to unit just will not fire up
The flo code indicates the the water pressure switch is open. If you know that you have more than the minimum amount of flow going through the heater, then the problem is a clogged or defective pressure switch. The pressure switch is located on top of the inlet/outlet header and can be found at an online store or a local pool and spa company. A generic may be used in place of the manufaturer part.
Feb 07, 2011 | Jandy Lite 2 Natural Gas Pilot Light...
My TL heater series 2, model ESC keeps kicking out after 5 minutes of heating..then kicks back in heats some more.. then repeats on and off cycle
Sounds like the high limits are shutting it off. Does the header on the output plumbing get almost too hot to touch? If so the flo-control disk may be bad or sticking, possible a dirty filter as well, in any case you may have insufficeint flow.
Mar 07, 2010 | Teledyne Laars Laars Lx Pool Heater /...
Will only run for about 5 min then shuts down, and will not light again. Gives a ILO and CFH on the board.
Without more info I would have to say you need to increase water flo through the heater. If you don't have enough water flo the heater will boil the water inside heater and shut down. The heater has a pressure switch that reads OK but you have by-pass valves that may be open or stuck letting too much water go by the heater. One on the pipes going in and out of the heater may have a valve bridging the two that need's to be 80-90% closed forcing water through the heater. Then there is another spring loaded disc inside the main water header that you can remove and clean or replace that does the same job only the spring controls the flow automaticly. Good luck and HAPPY NEW YEAR.
Dec 29, 2009 | Raypak Free Hydraulic Lift Gate Delivery -...
Heat not firing, read-out indicates "FLO"
you may have a bad pressure switch.if you are getting flow thru the heater and this code is comeing on there are only two reasons.No flow or bad switch.
Jul 06, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Pump not working
overheating and shutting down replace
Aug 13, 2017 | Aqua Flo Aquaflo Flo - Master Fmhp 1 1/2...
Sony KP 51HW40 Rear Projection tv red flashes
The +5 line is either shorted or overloaded on the A and B boards that what the 6 blink error code is indicating.
May 28, 2008 | Sony KP-51HW40 51" Rear Projection...
Jandy  Lite2 Lj175n 175,000 Btu Natural Gas Heater Logo
47 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
