Question about kawasaki Quad Bikes
Clutch appears to be slipping - kawasaki Quad Bikes
    President:
  • 1,167 Answers
Hi mate adjust the clutch cable on the clutch lever good luck
Posted on Jul 07, 2009
  • 30 Answers
Hey dude u gotta change ur clutch plate mannnn.....
Posted on Jul 06, 2009
Can the clutch be adjusted on an unidentified riding mower/tractor?
Probably not if its a hydraulic transmission. The first thing to do is fit a new drive belt as this is the most common cause of what appears to be clutch slip.
Jan 30, 2016 | Garden
TS6.140 New Holland tractor clutch appears to be slipping how do I adjust it 2013 year model
There a lever clutch petal hooked to. Unhook linkage, move lever toward back of tractor. Screw linkage to aleign with lever.
Jan 04, 2015 | Garden
Rav 4 clutch adjustment
it is the sign of the clutch wear surely. Do not delay the replacement because the slip you have burns the clutch with the flywheel overheated and will crack to need renewal which it is very expensive part. Also there is not any adjustment on it,it is a self adjusted clutch system.
Sep 20, 2012 | Cars & Trucks
Iveco daily transmission, seems to slip like clutch slip , but is auto trans. also smells like clutch slip. Barry R
thats because it is clutch slip ,auto boxes have a clutch in them ,the front clutch ,also check the oil level
May 02, 2010 | 2007 Fiat X1/9
94 Pathfinder, Manual transmission slipping a tiny bit. I want to add Lucas Stop Slip. How do I do this. Theres no Dipstick to check levels of TRANS FLUIDS
Adding Stop slip to a manual transmission with not keep your clutch from slipping. Replace or adjust the clutch.
Mar 13, 2010 | 1994 Nissan Pathfinder
I HAVE A MITSY DELCIA CAMPER 2.5 TURBO DIESEL AND I AM GETTING CLUTCH SLIP/JUDDER WHEN I PULL AWAY ANY IDEAS THANKS DB.
It sounds as if a couple things may be at play: one, wearing clutch, Two; the clutch pressure plate springs have become fatiqued not tranferring power as they should allowing the clutch to jump apart. It would appear you should replace both the clutch and pressure plate.
I hope this may have assisted,
Tom
Oct 26, 2009 | 1990 Mitsubishi Minivan
95 Honda Accord EX clutch occasionally slips??
May be a bad pressure plate, because if it was the clutch hydraulics the pedal will go to the floor. Good Luck
Jan 22, 2009 | 1993 Honda Accord
Clutch Slip
or at very low speed. The only way around it is to accelerate very slowly for a bit. After reading the forums I tried... -rolling the bike backward about 3' and examine the belt--the belt stays right at the top of the pulley. -examining the clutch--doesn't appear to be any rubber particles (shouldn't be as it was just replaced!) Also the drive belt is new. The only other thing to comment on is while I assumed I was buying a new clutch the red writing on the clutch indicates it is a rebuilt. That's all the info I have--any ideas?? Thanks! ,Slipping won't work for long. We have never seen slipping when all belt friction surfaces are clean. The belt should be totally dry and clean. The metal surfaces of both clutches can be cleaned with brake cleaner to remove any lubricants or oils that may be on them. Typically real slipping will destroy a belt almost instantly.,,,
Nov 10, 2008 | 2008 Ridley Auto Glide Sport
kawasaki Quad Bikes Logo
636 people viewed this question
Top kawasaki Toys Experts
Vernon Taylor
Awesome12
Gregg Mahin
Gregg Mahin
Are you a kawasaki Toy Expert? Answer questions, earn points and help others
