Hi guys, My CDW354 has sprung a leak, the filter connected across Live & Neutral blew apart last year and tripped RCD, I replaced the part and it worked fine until now, it starts ok, empties excess water before launching into cycle. As soon as it opens valve to allow water in the RCD trips, pulling it out from wall reveals a puddle so I guess theres a leak somewhere, Ive checked all visible pipes for leaks, even removed some a cleaned them to no avail.
Would it be safe to start the machine while its upside down so I can try to find the leak?
Ive taken some photos of the underside should anybody need to view it.
regards
Steven
SOURCE: LG LD-A2T2 Dishwasher returns Error code E1
EI is an error to do with your drain. Check your drain hook up. You should have a loop out side the unit, it should be a minimum 40in in height, or put in a air break. What I believe is happening is your unit is siphoning out. Fix this and you will be able to stop washing the dishes by hand.
Sgt 48
SOURCE: SMEG DWI410 TRIPS CIRCUIT LATE IN WASHING CYCLE
just possibly
take the kick panel off. On some smeg, there is a small suppressor capacitor on the lhs tucked in the wiring. this breaks down. snip it off - no need to replace
SOURCE: Overheating Dyson DC07
Many devices including this one have what's known as a thermal cut out.
It is there for obvious safety reasons and prevents the temperature in
the locality of the cut out from exceeding a pre-defined value.
Some of them require you to press a reset button in order to switch the
power back on and other types simply reconnect the electricity supply
when the temperature returns to normal (safe) operating limits.
The Dyson DC07 has a thermal cut out located close to the motor and it is of the "self resetting" type.
If your vacuum cleaner switches off after a few minutes the most
probable cause (there can be others) is the thermal cut out has
operated.
The first and most important thing to do is to establish why it has
operated.... If the airflow around the motor has become restricted then
it will not be being sufficiently cooled and so it will have cut out
correctly. However, thermal cut outs are often quite crude internally
and it is not uncommon for them to start cutting out at too low a
temperature. So...
Here's what to do...
(some tools may be required to complete the following so read the entire
procedure before starting. Please note this is not an absolute guide if
you need really foolproof step by step instructions... buy a manual!
But this should help)
Check all these parts for blockages/clogging before continuing...
There are now only two areas left that I know of which may cause
further blockages. One is the "whole of life filter" located under the
dust bin and the other one is inside each of those seven little cones
(cyclonic chambers) at the top of the dust bin (root 8 cyclone is
usually written on one of them). The following will require some tools
and some common sense...
If none of this revealed anything very positive... Its time to open up and inspect the motor casing/thermal cut out.
**** WARNING**** The next section requires someone who is technically
minded, has fiddly fingers patience and a basic understanding of
typical plastic goods assembly techniques. As I am not including
photo's the descriptions given can only be considered as pointers to
how to do it (I'm not writing a Haynes manual here! So if you are a cak
handed clot with little or no patience and a tendency to resort to ever
bigger hammers - take the vacuum cleaner to an independent repair shop
- explain the symptoms, tell them what you have done so far and leave it
to them!!
NB. NEVER remove or bypass the cut out. this really could be very dangerous!
I hope this is of some help... Regards to all.
SOURCE: DC15 Animal brush motor not working?
Same problem but all fuses etc ok I found that there are two wires that move with the head,orange & white located in the left hand bottom panel(side of vacume). they had broken bought some conectors from maplin & all fine now.
