Question about Frigidaire FAH12ER2T Thru-Wall/Window Air Conditioner
Frigidaire wall unit- 4 years old air conditioner turns on, however it doesn't cool and won't turn on at all for ''fan only''
  • dalemfine Jul 04, 2009
    I went outside to see I could tell what the problem was and believe it or not, there is a big birds nest in between the slats of the casing that houses the AC unit. I have a feeling that could be the problem, unfortunately I live in a condo and have to wait until Monday to deal with the maintenance manager about this.
  • 6,927 Answers
Try a fan run capacitor ,,,and the a new fan ,see if fan is stif to turn by hand if so replace fan
Posted on Jul 03, 2009
Why does my brand new wall AC unit turn on but the fan does not work?
Good Afternoon Michael,
I see that you are having trouble with your Frigidaire air conditioner, model# FRA14EHT2, and the fan not turning on, even though the compressor turns on. Being that this is an air conditioning, I suggest either calling your local authorized technician or possibly the manufacturer. One of which will be able to assist and direct you in the right direction of having your air conditioner working. Hope this is helpful.
-Best Regards-
WP
May 09, 2014 | Frigidaire FRA14EHT2 14,000 BTU...
Ac fan not running, but compressor runs on and off
switch/ fuse possible if it has one, if not one of the wire going to the motor was severed, or the start up capacitor of the motor if it also has one.
Jun 04, 2013 | Frigidaire FAX054P7A Wall/Window Air...
Compressor won't kick on 12,000BTU Frigidaire window A/C After cleaning
Is everything dry? Do you hear any noises like the compressor running it is just not cooling?
Aug 04, 2012 | Frigidaire FAH106N1 Wall/Window Air...
Air conditioner has loud hollow sound
After mine set up, I turned it on and it made a steady clanking sound, turns out there is black foam that is supposed to be glued behind the cooling fan and it had come undone and was hitting the fan. Slide the unit out of its shell and reach your hand in there and see if anything has come loose. (the fan towards the rear of the unit) good luck.
Mar 29, 2012 | Frigidaire FRA256ST2 WallWindow Air...
Cooling doesn't stay on
The outside and inside coils may need cleaning. Clogged coils cause excess pressures and heat of the freon that can cause safety switches to shut er down. Eveen a faulty power relay in the outside unit.Otherwise you may need a serviceman to locate the cause.
Jan 21, 2012 | LG LS-L1210CL Mini Split Air Conditioner
My frigidaire air conditioners spit dirt all over the floor. My window unit and my through the wall unit in a sleeve both do the same thing. I called Frigidaire two years ago and they told me there were no...
1. Turn units off
2. Remove Filter
3. Spray a foaming cleaner on the coils (Dow Bathroom Cleaner)
4. Use a spray bottle filled with plain water
5. Replace Filter and Grill
May 25, 2011 | Frigidaire FAC124 wall/Window Air...
HI,my air conditioner became really loud. it still works a little bit but not as good. sounds like someting isnt working right. frigidaire energy star model FAH106R2T. I TRIED TESTING IT AND RESETING IT...
Dave, a high pitch is usually a fault at the blower motor/dry bearings. Or an issue with the freon circulation causing a noise. And it being only a year old doesn't mean it's still a new unit. I've pulled parts and equipment out of the factory packaging, and it was junk, broken, or damaged. Try turning the cooling off and fan on only. If the problem persists with the fan only, you're certain that the trouble is there. Try to see if something is on the blower wheel/blades. Debris or plastic?
Aug 21, 2017 | Frigidaire FAH106R2T Thru-Wall/Window Air...
No more cooling.
check filters and depending on how new the unit is they dont operate as cold as the older units did
May 17, 2009 | Frigidaire FAA065P7A Thru-Wall/Window Air...
Fidgerdare electrtolux air conditioner
have you brought it down for a general cleaning on the 3 year period? if not then that's what it needs now.
the coil is freezing up because of dirt accumulation on the coil. even there is a filter, still with in 3 years it could have accumulated to decrease the airflow thru the coil and freeze it up.
tnx 4 using fixya,
drcool
Sep 07, 2008 | Frigidaire FAC124 wall/Window Air...
Frigidaire FAH12ER2T Thru-Wall/Window Air Conditioner Logo
343 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
