Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Red float keeps popping up
The red floating ball that should pop up to indicate the dirty water tank is full pops up within 30 seconds of turning on the machine, despite the tank being empty.
  • jimkeyss Nov 29, 2007
    steam vac red float ball pops up within 20 seconds of turning on the machine.
    have cleaned the dirty water return tank and still this problem persists..
  • wonone Dec 29, 2008
    I have a Hoover Steam Vac Deluxe Spin Scrub - Model F5862-900. The red float sucks up after the first tank and then keeps sucking up sometimes as soon as the vac is turned on. Rather than cut 3/4" off the open end of the 'sock' filter covering the float, I folded it back. It sucked up soon as the vac was turned on. Removed the 'sock' filter and it worked fine. Cannot see why this would harm anything as long as you watch the tank so as not to get too full.
    Any other ideas would be helpful.
You need to clean the debris channel. Put the machine on a waist high flat surface open it and remove the dirty water container. You will see three vertical screws which lock the scroll above the motor to the clear plastic panel at the front of the machine. Open these screws and remember which one belongs where. To the left of the scroll, there is a black horizontal screw which should also be removed. If you look closely, you will see the right hand of the first three screws (brushes face to your right hand) has also released the plexiglass (clear plastic screen where you see the dirt and soap flowing at the left side. Now put the machine on its side and look at the front edge of the plexiglass just ahead of the brushes. There are two screws which have to be removed - one on each side and bingo the plexiglass shape lifts clear. Clean out the muck, check the scroll channel for similar muck and reassemble.
The muck is plugging the dirt path and fooling the red float that the tank is full.
Re assemble the reverse of the disassembly procedure. Do not use a power screwdriver as you will likely shear the screw heads.
Good luck,
AMSW
Posted on Dec 30, 2008
Occassionly my does that. I just keep turning off and on until it stops. I would not remove the black mesh if I was you. Your black mesh may just need cleaning. I have a dog and my mesh always have hair on it. I believe that mesh serves as a filter. May not be allowing the correct air flow because it is dirty.
Posted on Dec 04, 2007
I seem to have found a solution to the red ball float popping up.
I removed the black mesh that covers the red ball float and just left it off. Without it the Steamvac works like new,,, although I don't know why this works but it does,,,
Posted on Nov 29, 2007
    Problem Solver:
  • 12 Answers
Don't permanently remove the filter, instead, cut approximately 3/4 of an inch off the OPEN end of it and put it back on.
Bissell carpet cleaner manual
Check the dirty tank for proper assembly and how full it is. There is a red float ball in there that might be stuck closed.
Sep 06, 2014 | Bissell 9500 ProHeat 2X CleanShot Upright...
Red ball stops operation why?
It is a float that signals the tank is full. It floats up as the tank fills up. When it gets to the top it cuts off the suction so it does not stuck water into the motor
Jul 28, 2014 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Why does red ball stop operation?
Hi there! The red float is there to let you know when your dirty water tank is full and needs to be emptied. If the float is popping up and the dirty water tank is empty or not full this is an indication that the dirty water tank filter is dirty and needs to be cleaned or replaced. Follow the link below to order a replacement filter for you vacuum.
Search Results
Hope this helps!
Willl not vacuum up the water
Means the suction is clogged by carpet or other debris take apart and clean as necessary.
Apr 13, 2010 | Hoover SteamVac F5914-900 SpinScrub...
I have never used a shampooer before when I use it it says to empty out dirty water. I don't have any left. My tank is empty. Am I doing something wrong.
Suggest that you do the following.
Remove the TOP ("Clean water") tank. Fill it 1/2 full of water. Put the top on the clean water tank and place it back on the machine.
Release the machine handle and remove the cover of the "dirty" water tank. Inspect the back of the tank to be sure that the vacuum adapter in located in the rear of the dirty water tank. If not-that is your problem. If yes, restore the top to the dirty water tank.
Power the machine on.
On a kitchen floor, power the machine on. Pull the trigger and hold it for about 30 seconds. You should see water gathering around the brushes. If not, that is a problem.
With water around the brushes, release and lower the handle and and move the machine over the water. It should vacuum the water into the dirty water tank.
Is all of that happening?
Nov 25, 2009 | Hoover SteamVac F5914-900 SpinScrub...
The red ball pops up periodically; why is that?
The red ball is the float/shutoff for full tank. That prevents water from overflowing and being sucked in to the vacuum motor. When the float shuts off the vacuum to the tank, the tank needs removed and emptied of dirty water. The float may get activated prematurely if the foam sock around it is dirty. It may be removed and rinsed.
Oct 30, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Automatic shutoff red ball in recovery tank rises to top when recovery tank is about 20% full.Thus we are only able to use the steam cleaner for about 2 minutes before having to empty the recovery tank....
Your cleaner should have a foam sock around the float cage in the recovery tank. Remove the foam sock and rinse it out with clean water. If these are very dirty, they may cause the airflow to be disrupted, causing the float to raise prematurely.
Oct 29, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
No suction on the bissell lift-off revolution
I had the same problem. In the water resevoir, there is a red flap that allows the dirty water to flow back into the water tank. Lift that flap up and there is a small red screen. Pop that screen out with a butter knife and rinse it out. I have dogs in my house and that screen was blocked by dog hair. I cleaned the screen, popped it back in and it works like a new machine. You would think Bissell would address this roblem on their web site but they don't.
Mar 09, 2009 | Bissell Lift-Off(R) Revolution(R) Turbo...
I cant get it to ****
This is from the owners manual that I have provided a link to, so that you can have a copy for your records. I hope this helps.
http://www.bissell.com/images/UserGuides/9500_908.pdf
Possible Causes Remedies 1. ReadyTools dial may be at wrong setting. 1. Set ReadyTools dial to either FLOOR CLEANING or TOOLS setting. 2. Tank may not be seated properly. 2. Pick up both the 2-in-1 water tank and formula tank and reseat them so they fit snugly on the unit. 3. Tank may not be assembled properly. 3. Check to make sure the "lip" of the nozzle is securely hooked into the groove on bottom of Tank (see page 9). 4. Solution or 2-in-1 water tank is empty. 4. Check fluid levels in heavy duty bladder and formula tank. 5. 2-in-1 water tank has picked up 5. Empty 2-in-1 water tank. Refill maximum dirty water and red float heavy duty bladder with clean door has closed. hot tap water and replace. 6. Red float "door" in the tank may have closed 6. Turn the machine OFF ( O ), as a result of bumping an object or moving allowing red float door to release into machine back and forth too quickly. the open position. Turn unit back ON ( I ) to continue cleaning. Be sure your forward and backward strokes are done at a slower pace.
Jan 22, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Float problem with Hoover Steam Vac Deluxe
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter.
Dec 16, 2007 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
2,742 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
