Question about Kenmore Dryers
Dryer won't start. just does a brief whine and
Dryer won't start. just does a brief whine and cuts out. more like a little groan.
  • 2,071 Answers
Check all of this
  • Check the outlet voltage
  • Test the door switch
  • Test the start switch
  • Test the safety fuse
  • Test the thermostat
  • Test the timer motor
  • Test the motor
To measure the voltage at an electrical outlet requires the use of a multimeter. Always test your test equipment for proper operation before use.
Set the multimeter to AC voltage. The markings may appear as VAC, AC V, or a V beneath a wavy line. Choose the AC voltage closest to the voltage you will measure. Standard current in home and businesses in the USA is in the range of 110 to 120 volts. Some circuits used for equipment such as dryers, air conditioners, electric stoves, ovens and other large equipment may use voltage in the range of 220 to 240 volts. These heavy-duty circuits can be identified by their non-standard outlet plugs.
Locate the start switch, it will have two or three wires connected to it. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Most dryers have a choice of temperature settings, therefore a separate thermostat is used for each setting. The selector switch or timer control then routes the circuit through the appropriate thermostat.
If a thermostat fails, it may prevent the heat from coming on, This happens because the thermostat does not close the circuit when the temperature falls below the operating temperature of the switch. It is a simple matter to test a thermostat; it should show continuity when the switch is cool and no continuity when it is warmer than its rated temperature.
A thermostat can also fail by being always on, no matter what the temperature. This switch would show continuity whether it was hot or cold. In this case, the heater would not shut off and the the dryer could dangerously overheat. As a safety precaution a second thermostat is used, a thermal fuse. The power will be cut to the heating circuit if the maximum safe temperature is exceeded. In most cases, this is a one time fuse. The heater circuit will not function until the fuse has been replaced. Of course, it will be necessary to determine and repair the underlying cause of overheating or the fuse will just cut out again.
The thermostats are usually grouped together. The are typically oval in shape and about an inch and a half in size. They may be on the blower housing, under the lint trap or inside the vent line. There should be two wires connected to each thermostat.
Good luck:
Regards:
VOTIT
Posted on Jul 03, 2009
Model #KEYS850GGQ0. dryer made bit of groaning noise on start up. Repeat next 4-5 starts, then would not start. Timer is ticking. Fiddled some with door switch. No help. Suggestions? Thank you, K C
Go to www.repairclinic.com and enter KEYS850GGQ0. With luck, you will be presented with a list of common replacement parts and may be able to view a generic disassembly video which will help you locate the source of the noise.
Jan 22, 2017 | Dryers
When the car starts power steering won't work
Have you checked the fluid level in the reservoir?
Have you noticed any fluid leaks?
Does the pump make a whining/groaning noise when you try to steer?
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Apr 20, 2014 | 2000 Mercury Villager
Whining/Groaning sound when turning/braking/accelerating
I had got help from its
manual from online store www.reliable-store.com. Here's the site link I am sure they will help you
Mar 03, 2018 | 1999 Nissan Altima
Have power everywhere but won't turn on
see this causes and fix it. God bless you
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.Thermal Fuse The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset.
Thermal Cut Out Fuse Kit Most dryers have several temperature control devices such as a thermal fuse, thermal cut out, high limit fuse or high limit thermostat. Some manufacturers sell the thermal fuse and thermal cut out in a kit. These kits normally solve no-heat problems rather than when the dryer won't start. However, in some models, this kit will solve both problems. Even though this is not the most common part to fail if the dryer won't start, both can be checked using an ohm meter or continuity checker. If they have continuity they are good. If not, they should be replaced.
Main Control Board The main control board is normally not at fault when the dryer won't start. First, check all of the other components in this troubleshooting guide before replacing the main control board. The main control board can not be tested and must be replaced if it is defective. If there are obvious signs of burning or a shorted out component on the board, it should be replaced.
Timer The timer is normally not at fault when the dryer won't start. In many situations where timers are replaced they end up being returned. First, check all of the more common components in this troubleshooting guide before replacing the timer. If the dryer won't start, the cause is much more likely to be a thermal fuse or switch. The timer can not be tested, it must be replaced if it is defective.
Oct 02, 2012 | Dryers
When start button pushed, motor tries to start turn, won't turn, shuts off after about 5 seconds. It's a whirlpool modle LGR7646eqo gas dryer, several years old.
The most probable solution is a new motor, but you may get lucky. I would first make sure that there isn.t something that fell down the filter hole and is caught in the blower blade. Possibly the rollers are jammed and won't let the drum go, but usually when it groans and won't go it is the motor
Apr 19, 2011 | Whirlpool LGR7646E Dryer
Bronco won,t start it whines , when i turn it
the drive is not kicking out on the starter. or may be loos.
Jan 25, 2010 | 1990 Ford Bronco
HP laserjet 1200 series printer makes a groaning whining noise when it starts up to print; noise continues until it stops.
Sorry, it's old, cranky, and worn out. Live with it, or buy a new one, it's not cost effective to fix it.
Oct 14, 2009 | HP LaserJet 1200 Printer
Dryer Starts... Then Stops!...
Sounds as if you have a bad motor. That humming is a big give away. Unless its less than 3 years. I would replace it.
Oct 29, 2008 | GE DBXR463EBWW Electric Dryer
Dryers Logo
26 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
