Question about Wurlitzer Jukebox CD Player
Rowe CD 100C Jukebox is set to free play but won't play entire cd
I have it set to free play and it works great, but it won't play an entire CD. When I try to select a CD and then press "popular" nothing happens. It used to work fine when I had the box set on pay. Suggestions?
SOURCE: rowe juke box
Put in service mode, type 55, then hold reset down while toggling 9 to cut on or off.
Should say free play on display.
Posted on Sep 26, 2008
SOURCE: Rowe cd jukebox
See your manual on how to enter SERVICE MODE. When you enter it the display will show SERVICE MODE. Then type, hold and push, or push the keyboard keys as follows:
Type 20 - display will show ATTRACT MODE ON
hold RESET key down and then push 9 key - display will show ATTRACT MODE OFF
push POPULAR key
The problem should be fixed and you can shut the door and resume normal operation.
Posted on Jan 15, 2009
Testimonial: "Thanks very much!!!!!"
  • 195 Answers
SOURCE: rowe jukebox
I take it that the jukebox accepts selections when you type them in. Also that you have tried selecting the A side and the B side records.
Is the switch on the CCC (Central Control Computer) set to Record it should not be set to Video.
Rowe Ami jukeboxes are very pone to dry (cold in the USA) joints.
If you can solder then the following items need to checked for dry joints.
Power Supply PCB (printed circuit board)
CCC
Mechanism Control Board
When taking out the plugs pull on the plugs (not the wires)
Look on the soldered side where the connectors pins are fitted for any cracking around the soldered joint ( this is the sign of a dry joint).
Resolder any suspect joints on all of the boards and refit into the jukebox and test.
If this does not cure the problem then the boards will be needed to be sent to a Rowe Ami specalist, I am one of these in the UK.
Regards
Alan Hood
ami-man
UK
Posted on Mar 03, 2009
  • 195 Answers
SOURCE: Rowe CD 100 that will not play all Tracks
Are you initalizing the CD's in your jukebox after you install them?
If so it should play all of the tracks.
Regards
Alan Hood
ami-man
UK
  • 195 Answers
SOURCE: Rowe CD-100-C Jukebox
Yes you will require a replacement CD player.
If you are in the USA then Bruce Wentworth is your man.
Bruce Wentworth
A&B Jukebox Repair
56 Old County Rd.
Plaistow NH 03865
Tel: 603-382-6272
www.abjukeboxrepair.com
Regards
Alan Hood
ami-man
UK
How do I set free play on my rowe laser100
Hi you put on service , then you enter 84 then you put the number of credit you want by example 9999 and you press popular and you put back to normal mode
Jul 03, 2014 | Wurlitzer Jukebox CD Player
Rowe CD100A Jukebox CD carousel keeps turning.
if you got the service manual with it, it will tell you how to pull up the error codes and what to check.....I got lucky cause I just bought one and it had the manuals in it...mines is a rowe ami cd-100c. ....I just googled ur model and a pdf manual pop up for downloading. ...hope that helps!!!!
Mar 14, 2013 | Audio Players & Recorders
I've had my jukebox for 6 years and the free play ran out. I forgot the code its a rowe cd 100 commerical
it should have a free credit button on thecircuit board they usually black or
red just press several times
Aug 21, 2011 | Wurlitzer Jukebox CD Player
Rowe Jukebox CD-100E. When I turn it on the
AT THIS TIME YOU ARE NOT SURE IF THE PROBLEM IS IN THE LASER ASSEMBLY, OR THE AMPLIFIER?
BORROW OR RENT, AN AMPLIFIER HOOK IT UP TO THE OUT PUT ON THE LASER OUT PUT ON THE LASER CD OUT PUT. LOOK AT LASER UNIT IT HAS A MARKING ON IT THAT SAYS AUDIO OUT PUT. PUT CABLE TO A SECOND AMPLIFIER.
THAT WAY IF IT STILL FADES. THEN THE CD LASER IS THE PROBLEM . IF THE SOUND IS GOOD THEN THE AMPLIFIER IS AT FAULT
DOCTOR FIX IT
Oct 23, 2009 | Wurlitzer Jukebox 1015 One More Time...
Regards
Alan Hood
ami-man
UK
Feb 01, 2009 | Wurlitzer Jukebox CD Player
Song Programming
With regards to your problem with the Rowe Ami 100 cd jukebox.
Do you have a manual, if not I suggest you buy a printer manual or one on CD and refer to the Programming and Installation section.
In order for the jukebox to know about the cd's that are installed in the jukebox it has to initialize all or the changed cd's that have been replaced within the jukebox.
Put the jukebox into the Service Mode (the service mode should appear on the display)
Type 3 to select the Initialize sub menu
Type 0 and full initialize will appear on the display
Press Popular to start the initialization
Place the jukebox service switch into the normal mode
Initiazation will take around 30 minutes to complete.
Regards
Alan Hood
ami-man
Jan 05, 2009 | Wurlitzer Jukebox CD Player
Rowe juke box
Aug 13, 2008 | Wurlitzer Jukebox CD Player
Open Questions:
See all Wurlitzer Jukebox CD Player Questions
Wurlitzer Jukebox CD Player Logo
571 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
John Robertson
John Robertson
Level 1 Expert
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
