Question about Xerox Phaser 6250DP Laser Printer
I have a Xerox 6250DP. it was working fine until I replace the black toner. Now, the quality of impression is poor and the black color appears and dissapears
    Scholar:
  • 141 Answers
The black toner may be packed into the cartridge. Take it out, beat it around a little to knock it loose, and reinstall it. It's possible that the supply auger in the cartridge is broken, causing inconsistent supply of toner to print engine. If beating it around doesn't bring you satisfaction, try to get it replaced by the vendor. If it's genuine Xerox, that shouldn't be too much trouble.
Posted on Aug 04, 2009
  • 17 Answers
I bet you used a Generic toner (Mediaq Science?)
this will contaminate the developer and cause poor prints. Vacuum, Replace developer, replace toner (Xerox Brand). Good to go.
Posted on Jul 19, 2009
Toner stick on paper very poor Xerox workcenter 7428 (Black color)
Your fuser has failed. You'll need to order a replacement. On some copiers, this is a user-replaceable part; on others you'll need to get a service tech to perform the work.
Dec 02, 2017 | Xerox Office Equipment & Supplies
Erratic black fusing
I'm not real sure about how the software separates the colors, but I believe there's a way to choose a color as all colors combined to make black, or simple black.
I'm not sure if I'm making any sense, but if the printer is using all the colors to layer up and make black, then it would be a pretty thick coating and that might cause it to flake off.
Oct 30, 2007 | Xerox Phaser 7700 Laser Printer
I replaced my black ink with a cheap brand that did not work. I then bought the expensive xerox ink and replaced it. I still get poor quality .. HELP
This printer is designed to print up to 50 000 pages trough its life. After that the transfer belt and the drum have to be replaced but the price is more than a new printer. So first check the counter (press the button and it will print it)
The cheap toner has entered in the black developing module where it mixed with the remained old original toner. They differ and tend to curdle. This is why printouts are poor after installing the new original toner. Try to print 20-50 black pages to take the curdled mix out. The developing module is part of the drum unit. It is hard to take apart and clean but not impossible. Buying a new drum unit is the last step, even after getting a new printer.
Aug 05, 2010 | Xerox Phaser 6110 Laser Printer
Print quality with black ink is poor throughout the page
hi, i have one of these to, mine is still running on the "test" inks as well but i have all colours in mine, anyway i digress, you can try, going to print something , when the chose printer box apears, choose cpl300 then choose properties ( to the right ) then choose graphics thumbnail, on quality choose best, then at the bottom you will see advanced options, then just click print all txt black, and click darken txt, and that should give you nice black txt....hope this helps
Mar 15, 2010 | Samsung CLP 300 Laser Printer
My xerox phaser 6250 prints the first page fine then the black fades on the following pages
Your toner supply route is partially plugged and it can't keep up with the demand. It's not an easy process to clean it but a can of air, toner vac, and an area you don't mind getting dirty are necessary. Pull the imaging unit out and dig around, blowing and vacuuming out toner. Also, pull the black toner cartridge and work through that way as well. If your black toner is low, that might be the problem.
Jul 13, 2009 | Xerox Phaser 6250DP Laser Printer
Phaser 6250 black toner is super light
http://office.support.xerox.com/SRVS/CGI-BIN/WEBCGI.cgi/,/?St=842,E=0000000000019251353,K=6024,Sxi=13,Case=obj(19377)
Click on Knowledge base from this site , then in the search box enter poor black quality. Look under black is faded or missing
Apr 08, 2008 | Xerox Phaser 6250N Printer
Xerox Phaser 6250 started printing bad
That really sounds like the imaging unit cleaner has an issue.
If you have one try the imaging unit, I really suspect that is your problem.
Black is Faded or Missing Step 1 Clean the Laser Windows and Remove Excess Toner From the Imaging Unit Step 2 Check or Replace the Imaging Unit Gear Retaining Pin Step 3 Replace the Imaging Unit (installation instructions) ic-film.gif
See if this link works. Xerox is infameous for these not working.
Apr 08, 2008 | Xerox Phaser 6250DP Laser Printer
Xerox Phaser 6120 color problems
I am running this one and I perplexed by what your saying.
Although I will offer some ideas.
I am running through my mind why the label would only affect the colors.
So some of what I am saying here is thinking.
That is a carousel color printer, and the label is confusing me, mainly since you said black is fine.
I can understand one color being off with the third party toners, but not all 3.
What you are having in some way has to be a contact issue, as if a piece of the label would up on a ground contact.
I would first try removing the transfer assembly, all the toners and the imaging unit, and carefully inspect for another piece of label.
Look at all the metal contacts on the cartridges and internally to the machine, see if one is dirty or somehow bent.
Go into you menus and run a color calibration series, and also do a memory clear, and NVM/NVRAM reset. But before you do any resets print out a configuration page to confirm your addressing if your using an Ethernet cable.
USB wont make a difference.
The reason I suggest the resets and calibrations is the label could have caused some high voltage arching and therefore corruption.
But, then again, why wouldn't that affect black and white. What does black graphics look like?
This one is making my mind spin.
Calibration makes sense because you say you have wrong color substitution, yet doesn't address streaky appearance That to me suggests a bad ground contact, But why only bad in color LOL.Ahhhh you have me nutty with this one. LOL.
I keep migrating back to software corruption or mis calibration.
Let me know if this makes sense or helps. Reading your problem makes me want to see this one.
Anyhow let me know if my rambling, which is rare helps.
Mar 14, 2008 | Xerox Phaser 6250DP Laser Printer
Xerox Phaser 6250DP Laser Printer Logo
217 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
