Can't get sound off my right speaker,,brand new cartridge, checked wires with VOM everything looks ok but no sound..I'm stuck
  • Joel Friedenberg May 11, 2010
    Try plugging the right channel RCA plug (red) from the turntable into the left channel of the amp. If you get sound, then you are getting audio from the turntable's right channel, and the turntable is not the problem. Also, plug the left channel of the turntable into the right channel of the amp to make sure the amp right channel is working( I'm assuming you are getting audio from the left speaker). If you still are not getting sound from the right channel, then the problem is with the amp right channel - maybe a dirty selector switch or corrosion on the amp RCA socket. If you rule out a problem with the right channel of the amp, then I would double check the turntable wires. First check the terminals and wires at the cartridge Do a continuity check from the cartridge terminals to the RCA plug and see if you have continuity. It could be the wire in the tonearm or the connection from tonearm wire to RCA shielded cable.
  • Audio Player... Master
  • 5,449 Answers
Is the amplifer working OK? Go to the phono input and put your finger on the right channel. It should hum. if it does not, you might have lost the internal preamp for cartridges. If it does hum then you need to recheck the right channel wires, conections etc. Don't forget you can change the conections over and see if the left channel will come on the right side.
If it is the preamp you might find an IC is the cause. Often these devices here are static sensetive.
Posted on Jul 11, 2009
Mid ranged speakers dont work. Only the stock sub and dash speaker works.
Is there a loose wire on those speakers? If not they could be played out.
Jan 28, 2015 | 2004 Cadillac Deville
Bose 321 no sound on auxiliary
Check the connections of the cartridge. If connection to cartridge is not right, this kind of fault can occcur.
May 12, 2013 | Audio Players & Recorders
Rowe r92 sound problem
Moving the wire indicates the speakers are OK. Try reversing the 3 pin plug from the cartridge. If the problem stays on the same channel, it is probably a preamp board issue. If the problem switches channels, you have a bad wire to the cartridge or a bad cartridge.
Nov 16, 2011 | Audio Players & Recorders
I have a Pioneer DEH-1300MP. Brand new. Just installed, and I have no sound. Everything turns on, even the remote works. But no music. Person who installed is 100% sure the wires were hooked up right. Is...
try checking the speakers and speaker wires for any shorts, grounds or bare wires. just one shorted speaker or speaker wire will shut off the audio completely.
Jan 28, 2011 | Pioneer Car Audio & Video
I have a brand new logic soundlab tx1002. it was hooked to a brand new radio and new speakers. When turned on, it is in protection mode. you get a popping sound from the speakers. we have checked all...
first disconnect one wire at a time, making sure the power is off. then connect power and check to see if your speakers are making the popping sound. when you do your speakers, make sure you disconnect both positive and negitive of each speaker at one time. when your amp goes out of protect mode you will have found your suspect wire. then trace to the issue. it could be as simple as crossed over possitive and negitive wires
cheers
Jan 11, 2011 | Logic Soundlab LSX2600 Car Audio Amplifier
Simply no sound from PC
Check if you have plugged in the stereo pin to the right port on the PC.
Open sound control (in control panel) and check if the both speaker(main volume) and the wave volume sliders are not set to the lowest.
Apr 02, 2009 | Computers & Internet
No sound from right front satelite
sounds like you have blown speaker swop them over and see if it works, if so you need repair shop
Sep 29, 2017 | Mission FS2-AV System
Prints in yellow instead of black
This could sound silly but are your cartridges in the right slots...
Try print a test page and see if your ink levels are ok.
Try doing an ink clean up.
BTW what is your printer's model no
Nov 12, 2008 | Office Equipment & Supplies
Open Questions:
313 people viewed this question
 Grubhead
Grubhead
