Question about Coleman 10' X 10' Sundome Tent 9160K101
Regulator on stove is clogged, how do i clean?
IF THIS IS A WHITE GAS STOVE/LANTERN, COLMAN FUEL OR GASOLINE, open drain tank,than unlscrew nut closest to the tank, turn cleaning rod into up possition or turn up fuel knob,unhook cleabing rod,leave in gen, if wont come out do not force, than remove tip on other end,if tip is not steel it will melt, heat gen,and rod till red hot leave on heat till carbon is turned to ash, on fire "camp" 30min. or longer should do the trick, torch will work to. gently up and down if rod does not slide rite out,mite have to repeate heating prosess, blow out ash after cold and rod slides freely. than reassemble, being carefull not to bend cleaning rod tip "inner rod" on lanterns do not over tight soft tip, when lighting after cleaning, some times hard to light until ash is worked out of rod and gen. works great! if to dirty replace.
Posted on Jul 12, 2009
How do I adjust the flame on a MGC5430 gas cooktop? Flames are too yellow and cause black soot on bottom of pans. Doesn't seem to have an air shutter adjustment
Is this unit set up for natural gas or propane? New stoves usually come with ORIFACES for both gasses. They would install between the on/off knob and the burner tube under the stove top. They may be tapped to the under burner area of your stove. If you lift your top stove cover you may find them. If you don't find them, you may need to purchase the correct applications for your stove. GOOD LUCK FRIEND.
Nov 28, 2014 | Maytag MGC5430 Gas Cooktop
How is air supply regulated in wood burning stoves?
To regulate air flow, there are damper devices built into the stove, flue and stove pipes. Keeping the air flowing correctly through a wood-burning stove is essential for safe and efficient operation of the stove. Fresh air needs to enter the wood compartment to provide oxygen fuel for the fire; as the fire burns, the smoke must be allowed to rise through the stove pipes, and exit through the chimney.
May 07, 2013 | Home
Regulator on colman stove 425 doesn't shut off fuel
If you mean it keeps on shooting out gas when you turn the knob, that sounds like the valve has a problem, likely a tiny piece of dirt in it. I am not sure there is any fix other than to take it out and clean it, or replace it.
If for some reason you are sure it is a regulator problem, then just change it for a new one - available at many stores that sell Coleman.
Feb 06, 2013 | Coleman 425 Camping Stove
Looking for the operating manual for a WFS43W-1 stove / oven from white westinghouse. Anyone can help me?
First, I'm Not a westinghouse tech.
* call vendor for service. Gas leaks are hazardous and require a qualified tech to service.
*** The following is for information only.***
* I've always had problems servicing gas stove, heaters, boilers, etc. Lots of unique components that require special tools to service.
* I was surprised to find out that it's better to call on your local Gas Supplier for service. The not only check the supply line but also have a very good working experience with all types of gas fired equipment.
* Slow pilot lighting or burner fire usually means a clogged gas vent or valve. If other burners are working fine, then it's just that particular burner.
* If all burners have the same symptom then it could be a number of things.
* Check gas mains for pressure and flow (you need a gas meter for this but if you have another stove on the same line then it's probable that the mains are okay. Unless the connector or shutoff valve is not working properly (partial open).
* Check gas hose to stove for kinks. Replace if bent (re bending will crack a metal hose.)
* Check the gas regulator (again, need a gas meter)
* Check the feed and branches for gas. If pilot lights are not on then there is a good indication that your not getting gas to that section. (or the pilot is clogged) Clean, clear, or replace pipes/parts.
* Check valve on each burner. This is the most used item on the stove. Expect it to wear out. Replace as needed.
* Final, Be safe; Call your Gas company or MFR tech for service.
Aloha, ukeboy57
Jul 12, 2010 | Kitchen Ranges
Clogged regulator?
Disconnect the disposable bottle and make sure the stove's gas adapter is not clogged with insect debris or something. Also make sure your bottle is not empty by trying another one just in case! Douglas
Jul 10, 2010 | Coleman Grill
Country flame nps-1000 made in 1996 has a lazy flame, low heat output, and having a difficult time regulating auger feed any suggestions
not getting enough air -clean and vacuum unit and check fresh air flow damper is not opened enough need more air or flue clogged and needs cleaning
Feb 15, 2010 | Napoleon Auburn Pellet Stove Heater
Gas won't flow through range
might be a clogged line, could be your diaphragm in the regulator that is bad, you will need to disconnect the regulator where you hook up your gas line to the range then from the burners blow compressed air through them, I would suggest replacing the regulator, should cure the problem.
Jan 19, 2009 | Stoves 600SiDOm Gas Kitchen Range
Coleman propane stove problem
The connector for attaching the regulator to a disposable propane cylinder has a sintered bronze filter in the tip of the brass probe tube that is prone to clogging, or the bronze pellets get mashed down over time, restricting gas flow, and this will cause a portable grill or camp stove to perform poorly. The filter is so fine that it takes very good eyesight and bright light to see that it isn't solid metal, or use of a strong magnifying lens. The best solution is to buy a new Coleman regulator assembly. If you are unable to get a new regulator assembly and have the skills and the tools, you can try drilling a very small hole on the side of the probe tube with a #60 drill bit, just below the bronze filter, but near enough the end of the tube so that the hole will be past the plastic seal when the disposable cylinder is fully screwed into place. You should avoid drilling directly into the end of the probe tube, as the end of it is used to depress the Schrader valve in the disposable cylinder to allow gas to flow. A #60 wire gauge drill bit is only 0.040 inch (1.016 mm) in diameter, but makes a hole large enough to supply sufficient gas to a portable grill or a dual-burner camp stove. If you choose to perform this work, the probe should be unscrewed from the regulator body and the Schrader valve core in the probe tube should be removed before drilling. Be sure to clean all brass and bronze particles out of the probe tube before re-installing the Schrader valve core and the screwing the probe into the regulator. Use a removable-grade thread locking compound to secure the probe in the regulator body and don't over-tighten it, so as not to crush the rubber gasket. Allow the thread locking compound to cure for several hours before attempting to use the regulator. Keep in mind that this modification increases the likelihood of dirt getting into the needle valves and jets of your stove or grill, which can cause maintenance problems in the future.1_28_2013_4_49_27_pm.jpg
Aug 19, 2008 | Coleman Gas Grill Stove
Why is my stove causing a thick coat of soot to buildup on my pots?
you have to adjust the air intake holes at the valves. this will give you a blue flame.
Aug 16, 2008 | Coleman Propane Grill Stove 9921-700
Coleman 10' X 10' Sundome Tent 9160K101 Logo
434 people viewed this question
Top Coleman Sport & Outdoor - Others Experts
Vernon Taylor
David Payne
David Payne
john h
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
