Home | Hitachi | 50V500 50 in. HDTV-Ready LCD Television | How do you fix a pin...
Hitachi 50V500 50 in. HDTV-Ready LCD Television
Problem for Hitachi 50V500 50 in. HDTV-Ready LCD Television
How do you fix a pink tv screen
By doulbled03 on Jul 03, 2009
Solution #1
posted on Jul 04, 2009
Somewhat Helpful)
Skyassoc
Rank: Guru  Hitachi Expert Televisions & Videos  Expert
Rating: 90%, 253 votes
There is one of two things to cause this. Either the Optical Block is bad or you will have to call a Factory Repair Facility out to reinitialize Data in the Service Mode. Regardless of which one it is you will need to call a repairman to verify. Hitachi will not give you the Procedure because you can corrupt
Data in the wrong registry and that could be real bad. If it is the Optical Block, It is not worth investing the money it the repair unless Hitachi helps with the cost.
Hope this helps,
Skyassoc
Was this helpful?
Yes
No
Popular Solutions for Hitachi 50V500 50 in.
Questions and Unsolved Problems for Hitachi 50V500 50 in.
Do you recommend Hitachi 50V500 50 in. HDTV-Ready LCD Television?
Answer
Answer
new tv installed ihave sky tv but can not us volumn on sku remote
Answer
I have a sonicview monitor vx2235wm. I unplugged it from the computer and moved the computer. Now... (More)
Answer
Purchsed 2 Hitachi 50V500 tvs in 2005 - first one developed blue line down the center in Q2 2009 -... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hitachi 50V500 50 in....:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
