Question about Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX
Difficulty starting Poulan 2250 . . .
I can't find the manual and forgot the instructions on how to start it - I know I prime it, and if it's cold pull out the little blue lever - but I think I'm forgetting something important because starting it is very hit-or-miss. thanks
  • 12 Answers
Hey pete
This is easy, prime bulb 5 to 7 times with choke lever full out. Pull string, once engine starts turn off choke and pull string again. ( throughout process do not pull trigger )Engine should start, let it idle 30 seconds, then finally pull trigger to rev up engine.
Posted on Jul 06, 2009
    Brigadier General:
  • 4,088 Answers
Be a little generous with the "little blue lever". Release it after the engine fires a short burst. The carburetor idle adjustment might be a little lean--turn it 1/8 to 1/4 tun CCW.
Posted on Jul 04, 2009
  • 45 Answers
If it's flooded, (ie: smelling gas?), remove the spark plug and dry it off with a rag., Open the choke and depress throttle. Pull the engine over a few times to purge cylinder of raw fuel. If you ground plug while doing this, you should be able to confirm a spark (ignition working). Put plug back it and try again with choke and throttle wide open and release trigger immediately when it starts. Oh yes, avoid ethanol blended fuels in all your small engines.
Posted on Oct 25, 2013
How do I cold start a poulan kd100 chainsaw
prime it and with switch to off position pull rope 3 or 4 times . turn switch to the on position and pull the rope again with choke pulled out .
Aug 08, 2016 | Poulan Garden
Not turning over
With switch off pull cord 4 or 5 timeslet it then try to start that pulling kinda warms the saw up so it s not a and cold start ,fluids got moving thing get primed
Jun 01, 2014 | Poulan Garden
Poulan Pro Chainsaw, PP3516AVX
is the cap vent plugged?
Aug 18, 2012 | Poulan Garden
I have a 2250 16inch poulan chain saw the primer has disintergrated\r\nit came to bits as i was priming. were can i get a replacment part i am from perth WA or get it repaired
Are you near Wenatchee? Here is the address of a place there where you can get Poulan parts.
BOB'S ENGINE CLINIC 611 B North Wenatchee Ave.
WENATCHEE, WA 98801
If you're near Leavenworth, here is another:
VALLEY 11756 US HIGHWAY 2 STE 2
LEAVENWORTH, WA 98826
Also, here is a website that you can order from: http://www.ordertree.com/poulan
Hope this helps. If it does, please place a vote or comment for me. Thanks,
Handie Andie
Mar 30, 2011 | Poulan Garden
Bought a Poulan Wild Thing 18" gas chainsaw (P4018WT) secondhand from someone who only bought it to cut down 3 trees. It will not start. I know that it works, as the guy started it up and showed me how...
Don't prime it 6 times.
Prime it once and try starting. Keep trying with one prime.
If that doesn't work, let it sit for a bit. And then prime it two times and try starting again.
If that doesn't work, try priming 3 times.
Then try half-choke with one pull only, and then move choke to run for the second pull.
The saw might have an on-off button
Oct 15, 2010 | Poulan Wild Thing 18" 40cc Gas Chainsaw -...
Hard starting,but when started runs good,then put it down on ground it shuts off,always ran good before just recently had this problem.
The choke isnt rattling its way back to cold start position is it? Had the same problem but with my backpack blower. Keep an eye on the choke while its on the ground. Also, check the priming pump, that little button you push to prime it, make sure there isnt a leak coming from there.
Jun 06, 2010 | Poulan 18" Wild Thing Chainsaw
Floods out everytime you try to start no matter what you do .if i dont pump the bulb or choke it . gas comes out the exhaust
Clean the air filter. Clean the spark arrester (muffler - if it cannot exhale it cannot inhale). You can prime until your thumb bleeds - that is NOT the problem. To much choke almost always is. It is severely flooded Open and follow this BE CAREFUL - Extreme fire hazard.
Extreme Flooding by Dolfoff
Please follow this link, http://www.fixya.com/support/t3226410-no_spark_new_plug_but_continues_flood cursor down to “Best Solution”, while there click the “Was this helpful? [Yes]” button
I am going to make the following assumptions:
1. It is a Poulan PP4218(WeDoNotCare), start procedure the same.
2. You removed and verified there is spark (plug replacement recommended). The plug is dry (not flooded).
3. With the saw at waist height; the starter handle held; and the saw released. It remains against the starter handle or VERY slowly lowers with a distinctive pause during each compression stroke.
OM follows:
http://weborder.husqvarna.com/order_static/doc/NOUS/NOUS2004/NOUS2004_530165555-01.pdf
All Poulan CurrentModels
http://www.poulanpro.com/node4043.aspx
Type just the model numbers (choose the suffix after the list is provided).
It needs spark, fuel, and compression to run.
An overly rich mixture should not keep it from starting.
To much or to little fuel will (most start problems)!
The start procedures are on pages 9 and 10.
STARTING A COLD ENGINE
If the engine is cold - Please read the second NOTE: before trying to start.
If warm – read the DIFFICULT STARTING (or starting a flooded engine). I would try it with choke closed first (Pull to full choke; push to off choke). Hard starting is almost always flooded on a 2-cycle engine. You can prime all you like; priming does not inject the fuel mix into the carburetor. It circulates mix from the fuel tank through the carburetor and returns any excess to the tank
Reply below with what happens. I will help you as much as I possibly can. HTH
Lou
Feb 03, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How start poulan p3314
Go here (type P3314 in the “Model Number” window):
http://www.poulanpro.com/node5782.aspx
Open the second one (start procedures are the same – page numbers vary slightly)
The start procedures are on page 10. If the engine is cold - Please read the second NOTE: before trying to start.
If warm – read the DIFFICULT STARTING (or starting a flooded engine). I would try it with choke closed first (Pull to full choke; push to off choke). Hard starting is almost always flooded on a 2-cycle engine. You can prime all you like; priming does not inject the fuel mix into the carburetor. It circulates mix from the fuel tank through the carburetor and returns any excess to the tank.
I hope you found this helpful. If you have questions or need additional assistance you can reply below.
Lou
Jan 23, 2010 | Poulan 14 in. 2.0 Peak Horsepower Electric...
Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX Logo
1,002 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
