Changed switch and there is still no power - Heating & Cooling
    Scholar:
  • 70 Answers
Check breaker and outlet. If you have power then you need to check cord as wire may be broken. You need to check with a volt ohm meter. Some things are hard to solve without a meter.
Posted on Jul 03, 2009
Changed starter and ignition switch on 350 with HEI, I lost all power from switch and it shorts the battery to completely dead. I got the problem from someone else who installed the motor. It is in a 68...
Not sure I follow you. Are you going to rewire the key switch power source back to the starter post ?
And the truck is actually a 1968 instead of a 1986 ?
Aug 11, 2013 | 1986 Chevrolet C1500
Wont power up
My wont turn on too, There is a orange light on the tower, Green on the left, Battery ovel, If I push the restart button, also switch the power supply switch in the back, also unplug from it, Sometimes does it, Do ou know whats causing this to happen, Please let me know Thanks
Jan 26, 2013 | Asrock K10N78M Motherboard
Computer will not power on and I changed the Power circuit board and the switch to turn the laptop on, the little 2 buttons. The battery and power supply is good, should I change the motherboard or what?
1. this is a possible defective coaxial connector on the motherboard that need to either be sweated ( re soldered) replaced.
2. the mother board will have to be removed to check the solder joints at the connector point.
3. if you have changed the switch module and you have problems then it may be at the switch module contacts. Make sure you have the switch module correctly seated.
Sep 14, 2011 | Computers & Internet
1st no power to coil 2nd now no power to starter Starter is new coil pack new and checked out ECM changed twice all senors changed Timing chain changed.was real loose, just changed switch on top of...
In older cars, the natural wear and tear on a vehicle can lead to ignition switch failure. If the switch is failing, you will probably not hear any clicks from the main relay, which fires the ignition. Check the behavior of the dashboard lights if your vehicle stalls. Alternatively, when the key is first turned to position two, the oil light, brake light, charge light and other warning lights will not function. You can try a test to check the integrity of the ignition switch by turning the ignition key to the 'start' position. As soon as it tries to start let go of the key. Allow it to snap back to the 'run' position and note warning lights. If they go out as the switch snaps back then the switch is faulty. if faulty it will not let power through to the starter to start car. check all fuses first. but sounds like switch.
Jan 31, 2011 | 1987 Oldsmobile Delta 88
System dead - checked switch, changed Power supply
Your motherboard has been faulty.you can repaired it from service center.
May 10, 2010 | Computers & Internet
96 ford explorer wont start. all power when turn key. nothing.
if it turns over from below,then its in the ignition switch and this also feeds power to the e.c.m. to make the engine fire so you either have a bad switch contact or the hot 12 volt wire to the ignition switch
Mar 20, 2010 | 1996 Ford Explorer
Sounds like either you have a faulty memory stick, faulty CPU or CPU fan or a faulty Mobo..
Mar 16, 2010 | Computers & Internet
Wd645 has no power to on/off switch. changed plug
Could be mains choke. Mains power comes into mahine via wall socket /worth checking this then onto mains filter/Choke..then to switch..So if no power here check this..wish you well
Oct 07, 2009 | Hotpoint Aquarius WD640 Front Load...
1996 CADILLAC DEVILLE, NO POWER TO FUEL PUMP
Check for a burned fusible link under the hood. If you have power at the fuel pump relay, you could have a bad ignition switch or bad oil pressure switch...accordianman
Dec 15, 2008 | 1996 Cadillac DeVille
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
