Question about Canon PowerShot A570 IS Digital Camera
My Canon powershot A570 is will not turn on, have tried new batteries and still will not work
Get a new camera...this camera sucks...wasted tonnes of money on new rechargables...just didn't last long for more than 50 shots each battery change...after that, it couldn't turn on after connecting to DC input....just get a new camera and chunk this away....
Posted on Sep 26, 2009
BillB-SA
  • 2761 Answers
SOURCE: My Canon PowerShot A570 IS wont turn on and it was
Your problem is likely due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you're using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may be due for replacement, or the camera may have a problem that requires professional repair.
Posted on Dec 05, 2009
t00nz
  • 4738 Answers
SOURCE: My Canon PowerShot A570 IS won't turn on. I put
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Posted on May 19, 2010
t00nz
  • 4738 Answers
SOURCE: My canon powershot a570 is not powering on despite changing the batteries. Any suggestions?
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Posted on May 23, 2009
t00nz
  • 4738 Answers
SOURCE: CANON POWERSHOT A570 - CAMERA
It should still be under warranty. Call 1-800-OK-CANON to resolve this.
Posted on Oct 19, 2008
  • 4 Answers
SOURCE: Canon Powershot A570 keeps showing change the batteries
I had the same problem. Here's the solution. Go into menu settings, then over to tools, select reset all at the bottom of options list. You may have to re-enter the date and time. This solved the low battery problem for me. I hope this helps.
Posted on Aug 15, 2010
How do I open the card/battery door on my Powershot A570 Camera?
My canon camera does the same thing. Engage the button and use your fingernail to wedge between the battery door and the camera body. This should cause the door to slide open.
Jun 24, 2012 | Canon PowerShot A570 IS Digital Camera
Canon Powershot A570 IS Problem- Photos deleted when new folder was created?
I would seek professional advice, there is recovery software out there that are very good, you have tried two, if there is any chance to recover more you need to talk to someone that is experienced in these matters. Best buys may be able to help and worth a try, a camera repair store would be another option.
Apr 02, 2012 | Canon PowerShot A570 IS Digital Camera
I purchased a new laptop and it will not read the canon a570is disk. it gives me an error stating "the screen resolution to execute digital camera solution disk is not sufficient." help
No need to attention for it,just go on ,I have happen to this problem like this for several model of cameras,but it is just a OS mislead error sometime.By the way,confirm your battery for Canon PowerShot A570 IS is installed.
Nov 22, 2010 | Canon PowerShot A570 IS Digital Camera
My Canon PowerShot A570 IS won't turn on. I put new batteries in and checked the memory card. What else can I do?
May 19, 2010 | Canon PowerShot A570 IS Digital Camera
Apr 02, 2010 | Canon PowerShot A570 IS Digital Camera
Dec 05, 2009 | Canon PowerShot A570 IS Digital Camera
Battery problem
Remove stain from batt. location , spray it WD40 inside batt. compartment then use NiMH batt. enelop white color
Jun 17, 2009 | Canon PowerShot A570 IS Digital Camera
Canon A570IS lens frozen half way-no power
I have a a570 IS that the lense locked out on. fixing it was going to be the same price as buying new, so I took mine apart and after two tries, i fixed it. I would be willing to take a look at it for a heck of a lot cheaper than Canon can if your willing.
May 22, 2009 | Canon PowerShot A570 IS Digital Camera
Blank LCD screen on shooting mode, but does show settings. Will not take pictures. Replaying mode works, shows pictures taken before screen went blank. New batteries. What is going on??? Is it...
The Display button manually turns the LCD display on or off to save batteries. If you accidentally had turned the LCD off, It should only take one press of the button to turn it back on and leave it that way. As such, it's not you but the camera. The A570 IS is relatively new. Your camera is likely still under warranty. If so, contact Canon for warranty repair (see the following link):
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2113&fcategoryid=221&modelid=14905
Mar 15, 2008 | Canon PowerShot A570 IS Digital Camera
Canon PowerShot A570 IS Digital Camera Logo
517 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
