Question about Sylvania 6427FF TV
Sylvania 27 inch stereo flat screen tv
I was watching my 2 year old Sylvania 27" flat screen tv and heard a static type sound, then the picture had red horizontal lines with a red tinted background. No previous problems at all. What could the possible problem be and is it worth fixing.
  • 308 Answers
Re: Sylvania 27 inch stereo flat screen tv
This problem sounds like a short inside the picture tube itself unless a driver transistor failed that drives the red gun in the CRT. You may have to take it to an authorized repair facility if the picture tube is still in warranty.
Posted on Apr 13, 2008
0 characters
3 Points
My 27 inch Insignia flat screen tube TV goes blank
The vertical deflection has gone out. Put it in the shop.
Apr 24, 2010 | Insignia NS-27RTV 27" TV
Screen got wide; nasty acrid smell like chlorine or ozone started
One or more electronic components was burned or deteriorated inside the tv.
Replace the TV.
May 24, 2009 | Sylvania 6427TE 27" TV
Philips 27 inch TV - Model # 27PT543S37A - Keeps going off!
if you have back ground of tv repair, remove back cover but you need tools and tester, check heater line from crt ckt board going to horizontal section.
Apr 03, 2009 | Philips Magnavox TP3285C 32" TV
My 27 inch Sylvania TV has no sound.
make sure not muted. otherwise many circuit problems can cause this. if picture good . prob worth tech ck out.
Dec 04, 2008 | Sylvania 6427GFG 27" TV
Haier 27 inch Flat screen Model: HFT27R11 Blank screen power led flashing with thump sound
seriously its a difficult problem, well sometimes the system control needs a heat-up by resoldering it. or caused by the flyback and the horizontal transistor. reply me if the problem persist. ^.^
Jan 22, 2008 | Haier HTF27R11 27" TV
Sylvania 27 in tv picture
It sounds like your vertical has shrunk, causing the picture to look squashed. Most likely a bad component in the vertical output stage.
Dec 19, 2007 | Sylvania 6413TC 13" TV
JVC i art 32" flat screen
Ur video ic inverter board is dead.
U need a new one.
May 13, 2007 | JVC AV-27530 27" TV
Speakers have died?
Probaby the stereo decoder IC went bad or a supply voltage to it is too low or noisy. If it has audio output jacks on the back of the TV, connect it to an external amplifier and see what that sounds like. If it is ok in stereo or mono mode then the amplifier in the TV is bad. This will prove that the stereo decoder is ok.
Feb 01, 2007 | Zenith C27A24T 27" TV
Sylvania 6427FF TV Logo
412 people viewed this question
Top Sylvania Standard (CRT) Televisions Experts
Kenneth Walker
Are you a Sylvania Standard (CRT) Television Expert? Answer questions, earn points and help others
