Question about GE Refrigerators
GE Refrigerator ZFSB25DMD SS, is not cooling or freezing.
SOURCE: GE GSH25JSTA SS side by side fridge not cooling/freezing
In most cases it is the Defrost timer circuit. One of three things the Defrost time (most likely) it allows the cooling for a 6 to 10 hour period and the defrosting for 10 to 30 minutes to remove ice buildup, ICE BUILDUP is the main problem as it restrict air flow, the cooling air circulation through the system. You see cool air only comes in the freezer side and passes through vents (pass ways) to the refrigerator side. Ice buildup in the freezer side inhibits cooling air to the refrigerator side. You think the freezer is working, but it is only cooler because there is ice in there that you can't see. The Terminator (a LIMIT switch) opens the defrost circuit if the defrost heater gets too hot (second likely) the next is the Heater which heats for those 10 to 30 minutes to melt the ice buildup (least likely) no matter the Unit you have they all have this circuit... Hope this helps, I'm Tango
Posted on Jan 16, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Refrigerator will not cool
Unplug power, pull refrigerator away from wall and gently remove and examine both sides of control board, Look for burn marks or smell of burns and then let me know what you find. Thanks, Sea Breeze
Posted on Mar 25, 2009
Sea Breeze
  • 4655 Answers
SOURCE: not cooling/freezing
Can you tell me more about your model GTS22IBMBRCC Are the lights on inside, are and fans running, do you hear any noise like clicking or the compressor trying to start. Is there a layer of Ice in the rear of the freezer? I can help just please respond with an answer, Thanks, Sea Breeze
Posted on Aug 08, 2009
aasc
  • 1606 Answers
SOURCE: 15 yr old GE TBX18SA refrigerator. Not cooling.
Remove the screw , on the left side of the control panel , and pull the panel , from the left side , outward to the right . You should now see , slightly to the right , from the middle , a black screw , a hole with slot , and slightly higher to the right , a hole with a white piece , with a hole in it . Now , the hole with the slot , turn with a screwdriver , until you hear/feel a louder click . Turn this slowly . When you hit the right click , the refrig will shut off . Remove the inside rear freezer panel ( and ice maker if equiped ) , by removing 3 or 4 screws , pop off the grill piece , and may have to twist the ice maker receptical slightly , to remove . If you do not see the heater on ( red ) , below the coils , then the heater is most likely the problem . pt # WR51x464 . Your old one , has a glass tube , but the new one , is calrod . I believe 2 screws hold this heater on .. If the glass heater does come on , then the problem is the defrost timer ( the piece you turned with the screwdriver ) which is removed , by removing that black screw and bending the panel out slightly . Pt # WR9X520 .
Posted on Nov 04, 2009
heatman101
  • 43501 Answers
SOURCE: Fridge not cooling, freezer not freezing even on coldest settings
From what you are describing, you have a refrigerant leak. The freon has leaked from the system, The compressor will still run and evrything looks fine. To double check you will have to have someone hookup gauges to the system and verify that the charge is lost.
It may be possible to find and repair the leak. This is not always possible as some of the system is virtually inaccessible in many refrigerators.
Make sure if you do have someone repair the system that they evacuate the system very well and do a good vacum test before recharging the system.
This should help you to solve your problem.
Thanks for using Fixya!!
Heatman101
Posted on Nov 24, 2009
Hi. Our GE GSH25JSDD SS side by side drive just stopped freezing, cooling. The fan is on inside freezer and lights, and motor down on bottom, back is running. Drain is clear. Won't cool down.
I need someone to feel the top of the compressor. Is it cool, hot or too hot to keep your hand there? Usually on GE models like yours the=> WR55X11072 Main Control Board is the problem along with the start relay, overload and run capacitor. GE Refrigerator Model GSH25JSDD SS Parts
I'm here should you have question, Thanks, Sea Breeze
Oct 10, 2015 | GE Refrigerators
Gss25xsrd ss GE fridge gets warm on the top (both fridge and freezer side) and freezes at the bottom. Ice completely melts and veggies in the drawers freeze too.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 26, 2010 | Refrigerators
The food in the refrigerator drawers (crisper and meat) are freezing and the waterline froze. What is causing this and is it worth repairing?
I have Ge GSS25XSQA SS side by side and the food in the refrigerator drawers (crisper and meat) are freezing. Also the ice dispenser is frozen closed. The water dispenser still works.
Want can I do to fix it. Would dirty coils have anything to do with this?
Terry
Nov 10, 2010 | GE GSS25SGPSS Side by Side Refrigerator
Ge refrigerator side by side , PSS26LRE SS, does not cool After manual defrost, it will work for several days and repeat again. Refrigerator bottom draw freeze everything. Please help
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Sep 11, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
GE refrigerater stops cooling/freezing and restarts?
maybe stuck in defrost cycle. usually controlled by a hv board on rear of refrigerator
Jun 21, 2009 | GE Refrigerators
Both Freezer and refrigerator are not as cold as they should be
We may need to look at the control circuit board the back of refrigerator if the refrigerator has stopped cooling. Let me know if the compressor is running or not. Let me know, I have a repair manual if you like.
Thanks, Sea Breeze
Apr 21, 2009 | GE Profile CustomStyle¿ 22.6 Cu. Ft....
Mar 24, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Jul 26, 2008 | GE Monogram ZISS420NRSS 42" Built-In...
Loose handles - GE monogram model # ZFSB25DMD SS
try removing the handle, that will expose the mounts for the handle. You should be able to tighten them after removing the handle.
Jan 08, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
300 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
