Question about Euro-Pro Shark 60 - 384
How to take front panel off shark euro pro sewing machine
Reverse stitch is broken. I went to sew a few stitches backwards, the handle went loose and now my machine is stuck in reverse mode for stitching. I can't get the front cover off to see if its a screw loose or more. Repair shops want $100.00 to fix it... anyone know how to get the front cover off?
SOURCE: Sewing machine straight stitch is not straight
Hey. It's full out possible that you have it on the right setting...but concider this - the switcher inside the sewing machine could be broken (ie. It's moving to different stitches - but not the one you have the outside set for)
It happened to me (pc o crap singer model)
Posted on Jan 24, 2008
RickE1
  • 202 Answers
SOURCE: backward stitching
Knowing which kind of machine you have helps alot. Just guessing but maybe the reverse mechanism is stuck and needs some oil in it to free it up. Or the buttonhole mechanism is stuck in reverse part of it.
Probably you should have it looked at.
Posted on Jan 11, 2009
Michaelle
  • 65 Answers
SOURCE: friends broke needle on my euro pro multi stitch sewing machine.
According to Euro-Pro.com
Where can I buy new needles?
Answer: The needles are universal and can be purchased at any sewingmachine notion department. The size and type of needles should beappropriate to the fabric used. See the needles and fabrics chart inyour instruction book.
http://www.euro-pro.com/europro/faqdetail.aspx?modelno=9000
has all the information including a downloadable manual (pdf file)
Posted on Jan 24, 2009
SOURCE: will not feed material or sew
Before you take it to a repair shop make sure that your one step buttonhole lever has not been moved by mistake. That happened to me just yesterday. If your machine keeps sewing in reverse all the time that could be your problem. It happened when I was going over all the parts in my sewing class. Although material was feeding through but everything was sewing in reverse. Check that out and make sure your buttonhole lever (#14) on the diagram is pushed up. I don't know if that is your problem but it is something you can try.
Posted on May 28, 2009
  • 136 Answers
SOURCE: Elna machanical sewing machine
50 year old elnas made stitches by cams. look to see if the machine has a cam in it. you can see this by opening lid on top of machine. cams are black with red or white showing the pattern of the cam. could also have broken cam stack gear. That would require technician with elna experience
Posted on Jul 12, 2009
Help? My hand-me-down euro pro shark only runs in reverse. any ideas?
re adjust the stitch length control its been left in reverse
Sep 28, 2014 | Euro-Pro Sewing Machines
What do I set for straight stitch on the shark euro-pro 384
It should automatically be set on straight stitch when it is switched on. Which means the needle is in the centre. (Hope this wasn't the reason you were given it.)
You can try Manuals on line as Euro Pro is hard to get hold of.
Sep 14, 2014 | Euro-Pro Shark 60 - 384
My sewing machine is sewing backwards how to put it properly?
You've most likely accidentally hit the "reverse" stitch button, which sews in the opposite direction. The button will be marked by one of these symbols: grtartst_1.jpg
This symbol indicates the reverse stitch button. Just press this button and your machine should start sewing in the right direction!
May 18, 2011 | Euro-Pro Easy Sewlution 385 Mechanical...
What is wrong with the mach if it misses the stitch on the bottom, it doesn't catch the tread? It doesn't make a clunking sound but doesn't sew.
Could be the needle is in backwards, not pushed all the way up into its housing or blunt. Try changing it first, rethreading machine top and bottom and try again.
If that fails and it is not forming a stitch at all, then the timing could be out and will need servicing.
Mar 27, 2011 | Euro-Pro Shark 9110 Sewing Machine
Lost manual to euro pro multi stitch 9000 machine. where can I get one
Lost manual for
How can I get one
Jun 24, 2010 | Euro-Pro Sewing Machines
I have a Shark by Euro-Pro and cannot find the straight stitch button.
Turn the knob on the font to 0 and see if that is the setting.
Mar 06, 2010 | Euro-Pro Shark 60 - 384
Shark 384 - how can i get a straight stitch?
with the Shark Euro-Pro X machine, you need to bring the stitch width to zero it's the nob on top of the machine the manual states not to use it wider then 3 with the double needle cause it can break the needle. but either stitch selection "A" or "S" will give straight stitching with width at zero.
Nov 19, 2007 | Euro-Pro Shark 60 - 384
Euro-Pro Shark 60 - 384 Logo
64 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
