Question about Kenmore Dishwashers
Kenmore Dishwasher Model 36315222100. Lots of water in bottom won't drain.
  • 641 Answers
SOURCE: dishwasher
Check whether the drain line was assembled exactly as per Kenmore's instructions. Good luck!
Posted on Sep 11, 2007
wheelshot
  • 102 Answers
SOURCE: dishwasher runs, water doesn't drain out
sounds to me that you may have some suds residue in the dishwasher that keeps it from draining completely. Get you some dishwasher cleaner which you can purchase at wal-mart or wherever you buy your detergent, and clean out your dishwasher. It is a inexpensive test. Alot less expensive than having a tech come to your house. Make sure that your drain hose is mounted higher that where it goes into the drain. This is also a common problem that I encounter in the field. Hope this helps. Let me know if I can help you futher.
Posted on Apr 04, 2009
SOURCE: I have a kenmore elite dishwasher that won't drain water out.
Check circuit braker.
Posted on May 30, 2009
  • 530 Answers
SOURCE: kenmore 665 no lights on panel water in bottom
This is commen with these. you need to take the door and remove the screws around it. You need to gain access to the controller. on the controller you will see a white peice with 2 balck wires going to it that is your fuse. replace this and that will solve your problem.
Posted on Jun 02, 2009
Macmarkus
  • 2605 Answers
SOURCE: Water in Dishwasher Bottom
Hello Richard, Welcome to Fixya ! You've come to the right place. The problem you're experiencing unfortunately is a common one. The water inlet valve has been an issue with B/S/H built ( this includes bosch, thermador, seimens & gaggenau ) dishwasher's going back to the mid 90's. The part to repair it is available at most brick & mortar appliance part centers or you can check out on-line vendors such as repairclinic, apwagner etc. Do a search for part # 1105846 at repairclinic, you'll see what I'm talikng about. By the way it's about $35. Hope that helps move you forward. Let me know if I can assist you further, or need help on how to change it etc. It's relatively easy with Bosch. Thanks for coming to "fixya" for your inquiries and please take a second to rate this answer according to my helpfulness. Goof luck. Macmarkus :)
Posted on May 04, 2010
What does E25 mean on my kenmore elite dishwasher model no. 639.140031.
Indicates a drain problem. Either blocked drain somewhere or defective drain pump
Nov 14, 2017 | Kenmore Dishwashers
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Sep 28, 2012 | Dishwashers
Hi we have a Kenmore Dishwasher Model # 13744K and it won't turn on. It has water in the bottom that won't drain. Please advise. Thanks. John Webster.
For a dishwasher that was rated pretty high by Consumer Reports, it does not clean very well. In addition, the plastic control button cracked in less than a year and I must constantly clean around the inside of the door ... and I never received my rebate.
Despite those issues, it has been a workhorse. My wife is a daycare provider and the machine is used twice a day (on average) and still runs well. On a monthly basis, I alternate a pint of lemon juice and a pint of vinegar to keep it clean and once per year I use a granulated dishwasher cleaner.
Aug 14, 2011 | Kenmore 13742 / 13744 / 13749 Built-in...
Kenmore dishwasher drainage problems
I have the same model -- and USED to have the same problem! We tried lots of things (bleach in the water, etc.). . . . and finally discovered it was a simple, standard concern. The drain tube from the dishwasher to the sink pipe was clogged with grease (looked like lard).
The way i knew it was clogged is that I disconnected the tube from the sink pipe, and tried to blow through the tube. It wouldn't let any air get through.
So once the dishwasher was empty of water (i removed the tube, drained into a big pan, and bailed a lot), we disconnected both ends of the tube.
With the tube in a trash bucket, I blew from one end (cleaned it off a bit first), and the "lard" came out. Drains beautifully now -- and did not require a plumber.
If you do this, be SURE you place the tube back ON the fittings EXACTLY in the same position and shape as before. This makes there are no new kinks or bends introduced into your drain tube.
Hope this helps.
E-mail if further questions!
Jonathan
May 30, 2008 | Kenmore 24 in. 16352 / 16354 / 16359...
Dshwasher has water on the bottom after cycle
your drain line is clogged or your pump is bad check both. the drain push a coat hanger down it and see if you can pull anything out.
Dec 08, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 17245 won't drain.
Try blowing into the drain line with a wet/dry vac. This sometimes removes clogs. Otherwise, hold the hose above the unit and fill it with water. If there is no clog the water should appear at the bottom of the dishwasher after a few quarts.
Nov 29, 2007 | Kenmore 17245 Dishwasher
Hi
Check the bottom of the machine and where water goes,there might be some scrap food,or other item that is not allowing the water to go in the time when the valve is open.This leaves some water and increases in other cycles,causing flooding on the floor.Also check for bend in the pipes at the back.
Hope this helps
jay
Nov 17, 2007 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwasher
Sep 10, 2007 | Kenmore 24 in. 16032 Built-in Dishwasher
Standing water in the bottom
try starting any program - all start with drain. if it doesnt drain, suspect a foreign object in the drain pump
Mar 29, 2007 | Kenmore 24 in. 15074 Built-in Dishwasher
Dishwashers Logo
120 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
