Question about Fuji FinePix S1000FD Digital Camera
When turning on my camera zoom error show up plus zoom lense will not extend
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Nov 10, 2010
Finepix j27 When the camera is turned on "Zoom error" message appears and lense is stuck in an extended position. When the power is turned off, the lense remains extended. Do you know how...
hi, Zoom Error occurs when there the lenses are not able to move and something is obstructing the movement like some dust or sand grains etc., to dislodge the obstructing particles try tapping the lense side corner of the camera on a table top lightly (not too hard please, as the lense and autofocus combination is quite fragile) a couple of times in switch off mode and trying to power on after every 2-3 taps.
or you might send it out to a service centre, the charges are generally just the serviceing charges as no new parts needed.
hope this helps
cheers
May 05, 2011 | Cameras
My EX-S5 says lense error
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 10, 2009 | Casio Exilim EX-S600 Digital Camera
Canon A540 powershot freezes with Zoom lense still out.
Probably the most common failure for all digital cameras, a lens error. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Jun 08, 2009 | Canon PowerShot A540 Digital Camera
Olympus SP-570UZ-zoom error
Had 570UZ for 2 weeks and "ZOOM ERROR" occured. Seemed hopeless. Changed batteries several times, bought new Alkaline.
No change. Finally decided that it is probably a connector problem.
Turned Camera Off. Held Camera by the lense barrel. Held palm of other hand and thrust the back of the camera ( LCD side) into the
other hand. The idea being to jostle the camera contents without cracking the LCD. Did this a couple of times, turned camera on and it works fine. At least for this evening. At least for now it seems like a classic component connector problem somewhere inside the camera.
Oct 30, 2008 | Olympus SP-570UZ Digital Camera
Zoom error
you may be true that sand must be creating this problem, as this happens very often. the sand enters into the lense assembly, creating friction in the movement. if this has happened total dismantelling and cleaning of the lense assembly will solve the problem, but that has to be done by an expert at the repair shop.
Aug 17, 2008 | Olympus Camedia C-350 Digital Camera
Error code S0042, DIMAGE G600
The S0042 error code relates to a problem with the zooming mechanism (lens would not retract or extended)
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. Let me know if it worked!
Feb 14, 2008 | Konica Minolta DiMAGE G600 Digital Camera
Zoom problem
sitch on when the lense extends take hold of the end and gently twist and pull the lense you may hear it click. be gentle do not force it then switch on and off again this should solve the problem
Jan 30, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Sony DSC-w50 zoom not working
switch on when the lense extends take the end of it and gently twist and pull the lense you may hear it click be gentle do not force it then switch off and on again and this will solve the problem 98% of the time.
Jan 25, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Panasonic DMC-FZ7 digital camera.
I believe the FZ7 determines that the lense cap is still on when it can't extend the zoom lense because the lense cap is in the way. I would check to see if your zoom lense housing is somehow stuck (could be sand or dirt in it) which is creating enough resistance to make the camera think the lense cap is impeding the zoom lense from extending.
Jan 03, 2008 | Panasonic Lumix DMC-FZ20 Digital Camera
Zoom error message
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Aug 07, 2007 | Olympus SP-350 Digital Camera
Fuji FinePix S1000FD Digital Camera Logo
53 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
